Results 1 to 8 of 8
Thread: LBZ Van ( original LLY tune) V3 programed, crank no start
    May 2025
    Default LBZ Van ( original LLY tune) V3 programed, crank no start
    I have the program loaded on the ECM successfully modules are ready.... Brand new CP3 etc. Cranking but no fuel coming through injectors. All components new. Will not start.Click image for larger version.
ID:	24877Click image for larger version.
    Did you flash a truck tune to a van ECM?
    May 2025
    No. Custom made tune for the LBZ Van. New Garrett better turbo, 30 over rebuilt injectors, new pumps x 3. New egr valve. Other than that not a true truck tune. Put a slightly modified van tune. Justice smidgen more power.
    I reloaded the factory tune four times this evening. In the process of loading the custom full tune now. It's been an hour still green process bar about 7/8th
    May 2025
    I did have it running badly a couple months ago briefly. But I had a pinched wire from bad installation I did at the camp position sensor. I checked for compression through glow plugs nothing bad.
    Jun 2022
    Do you have a lift pump?
    2016 LML
    May 2025
    Yes. Van has a stock lift pump. It's new. Tank pump new. Injection pump new which included Mprop. When bleeding the system it is pressurized very well. I think it's something with the programming or something no trouble codes.
    Jun 2022
    Based on your screenshot it looks like it’s trying to inject fuel. So you bled the fuel filter? Verified you’re getting fuel to the injection pump? Has the engine ever ran successfully while you have owned it?
    2016 LML
    If you've returned the ECM to bone stock and it still won't start, and there are no security related codes or indicators, it seems unlikely that it's the ECM or tune, but instead something hardware.
  1. 06 lly/lbz van tune wanted
    By FEDMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 5th, 2025, 04:31 AM
  2. 2004.5 LLY no crank/no start
    By littlesolidkick in forum Duramax LLY
    Last Post: April 29th, 2018, 02:05 AM
  3. LBZ pickup OS with van T42
    By DURAtotheMAX in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: June 25th, 2015, 01:45 AM
  4. Van LLY tune?
    By N0DIH in forum Duramax LLY
    Last Post: July 20th, 2010, 06:27 PM
  5. lbz tune on lly?
    By kregelsmax in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 4th, 2009, 09:59 AM
Tags for this Thread
