Results 1 to 4 of 4
Thread: LS1B vs P10 serial data
    Jan 2009
    Default LS1B vs P10 serial data
    I'm helping install a Turbo 5.3L (LS1B) into a 2002 Trailblazer that originated life with a 4.2L (P10 ECM). Does anyone know if the two ECMs share compatible serial data streams? (i.e., will the LS1B and TAC module 'play nice' with the 2002 Trailblazer's A/C, Cruise Control, Dash instruments, etc?)
    Flash the LS1B with an 02/03 5.3L V8 file from an extended TB and just remove the P10 altogether. It's a factory combo so should work well.
    Apr 2025
    Quote Originally Posted by Yellow05C6 View Post
    I'm helping install a Turbo 5.3L (LS1B) into a 2002 Trailblazer that originated life with a 4.2L (P10 ECM). Does anyone know if the two ECMs share compatible serial data streams? (i.e., will the LS1B and TAC module 'play nice' with the 2002 Trailblazer's A/C, Cruise Control, Dash instruments, Geometry Dash, etc?)
    Hello Yellow05C6!
    Have you loaded Flash the LS1B with an 02/03 5.3L? I tried it and found it quite stable.
    Banned
    Jun 2025
    Default Nice!
    The P10 and LS1B ECMs use different serial data protocols, so they're not directly compatible when it comes to modules like the BCM, IPC, or TAC. In a 2002 Trailblazer, the P10 communicates via Class 2 (J1850), while the LS1B from a 5.3L setup also uses Class 2, but implementation can vary depending on the donor vehicle. You may run into issues with A/C controls, cruise, and dash functionality unless you either reprogram modules to match or use a standalone setup for the engine and retain factory systems with a data bridge or custom tuning
  1. Replies: 4
    Last Post: April 5th, 2017, 05:54 AM
  2. Motec PLM Serial Data to V2
    By RetroAus in forum FlashScan V2
    Last Post: February 6th, 2016, 12:32 PM
  3. Camaro ZL1 E67 SERIAL DATA???
    By 400ss in forum E37, E38 & E67 PFI ECM's
    Last Post: September 21st, 2014, 08:42 AM
  4. Incorrect serial EQ data w/BBL
    By mr.prick in forum Black Box Logging
    Last Post: July 11th, 2010, 01:16 AM
  5. Do I need a PID to LOG serial data?
    By Chalky in forum FlashScan V2 BB Logging
    Last Post: May 15th, 2008, 11:16 PM
