Results 1 to 5 of 5
Thread: e38 Tach output RPMs too high (LS3 swap)
    Jul 2025
    Default e38 Tach output RPMs too high (LS3 swap)
    2013 Camaro LS3/TR6060 swap.
    Running tach output from pin 48 with a resistor pickup for the signal. I get signal, but it reads too high. I had high and low resolution set at 6, but it was reading approximately 2x what it should have been. I then read that 6 is for 4 cylinder and 3 is for 8 cylinder so I changed to 3 but now it's approximately 4x what it should be, so maybe I went the wrong direction?
    Screenshot attached, any guidance appreciated!
    What tach are you using?
    Jul 2025
    It's in a 1986 Jaguar XJ6 - so 6 cylinder tach.
    How did the car get original tach signal?
    Jul 2025
    It's a digital tach. I have tach signal already, I'm trying to get the right output from the ECM to get a directionally accurate signal to the dash. I think it will be 9/10 or 12/12...may just have to experiment and see what gets me closer.
  1. e38 Speedo output options (LS3 swap)
    By benji808 in forum E37, E38 & E67 PFI ECM's
    Last Post: July 18th, 2025, 03:51 AM
  2. no tach output
    By steve40 in forum Gen III V8 Specific
    Last Post: June 19th, 2010, 03:52 AM
  3. E-38 Tach output
    By MSURacing in forum Gen IV V8 Specific
    Last Post: February 10th, 2009, 06:45 AM
  4. Tach is off by about 200 rpms. Can I change this?
    Last Post: January 22nd, 2009, 05:58 PM
  5. LS1 PCM differences in tach output (F-body vs 04 GTO)
    Last Post: January 7th, 2008, 03:47 AM
