Page 21 of 22 FirstFirst ... 1119202122 LastLast
Results 201 to 210 of 212
Thread: Diesel tuning restrictions for USA customers
  1. #201
    Jul 2013
    Thanks for the info. I only do it to my truck and being that I just got a 10 lmm I wanted to make sure before I update. Again thanks.
  2. #202
    May 2008
    With a lmm you are fine
    2015 3500HD crew cab long bed, 6" fabtech, slightly tuned, emissions intact.
    2005 dmax ccsb, EFI live tuned DSP 5 Full built motor, S471 billet single, More better built trans this time. and lots of other things.
    1984 CJ7 powered by a 2000 LS1. 4L60E.
    2012 Jetta TDI 6 speed manual, (yes the dirty the bastard haha)
    2003 Jetta TDI,
    1986 K10 LQ4/4L80E
  3. #203
    Jun 2015
    I'm a newbie here and to EfiLive. I recently installed a new DPF (long story) and the exhaust guy messed up and welded the pressure sensor due to a stripped plug. Ive been having troubles since, the worst is that the egr is on all the time. I pulled the solenoid and it seems to be working properly, but it is fully extended when the engine is running.
    Instead of replacing the solenoid, I put it in the glove box and taped off the wire. The engine is running much better I need to smog in a few weeks, so I'm looking for a replacement DPF. I've got the V2, but I'm still going through the manuals and plan to tweak the tuning after smog.
    Question, Is it going to be ok to drive without the solenoid for a few weeks?
  4. #204
    Jan 2011
    Is this USA only restriction still the case? and if so, does it apply to the new V2 HD as well?
  5. #205
    Answered in the other thread you started.
  6. #206
    Jan 2011
    Yes for the HD, but is it still available outside the us for the regular v2?
  7. #207
    Nov 2005
    Quote Originally Posted by derkscustomcars View Post
    No platform EFILive has developed support for since about 2013 contains delete parameters regardless of hardware.
    Cindy
  8. #208
    Jul 2007
    I still have my old efi live that I haven't used since probably around 2010. I have software on a couple old laptops. This hasn't been updated. Someone should still be able to use for DPF delete, right? I don't want to update it and lose the ability.
  9. #209
    May 2020
    I am sure I am not the only one wondering this, but with the emissions restrictions potentially being eliminated in the US could we potentially gain access to emissions files if everything goes through?
  10. #210
    Sep 2023
    Quote Originally Posted by THAHN View Post
    Curious as well!
  1. Tuning on a customers tow rig yesterday
    By DoghouseDiesel in forum Cummins 5.9L
    Last Post: March 21st, 2012, 06:07 AM
  2. Diesel MPG Tuning
    By Climer97007 in forum Tuning For Economy
    Last Post: November 16th, 2008, 07:06 PM
  3. Diesel Tuning Class Now Available!
    By EFIGUY in forum General (Diesel)
    Last Post: December 4th, 2007, 02:40 PM
