Results 1 to 4 of 4
Thread: Unusual Problem (I Think)
    Jan 2009
    Default Unusual Problem (I Think)
    So this is an unusual combination. But I see this issue in my
    Jan 2009
    So this is an unusual combination. But I see this issue in my ’06 Z06 also. Low speed ‘chatter’. At 25-35 MPH in 1:1 drive the engine seems to surge then relax with the result being a lot of drivetrain chatter. Now for the combination: It is a ’72 Vette ‘restomod’. It is a GMPP ZZ6 350 ci engine with port injection / single plane intake / Holley throttle body and a 411 ECM (OS 12212431). The distributor is a ‘dual sync’ modified so that it creates both the cam and crank signals for a Chevy Express Van (Low Resolution Crank signal). The transmission is a Tremec 5 speed w/ a 3.73 rear end. The car runs great in all other conditions. But this combination even chatters in 3rd gear! I can minimize the problem by lightly cycling the throttle, adding load then reducing it. Any insight into how to eliminate or even just reduce this problem would be appreciated. Maybe disable Spark Smoothing?
    Aug 2018
    Can you post a log, possibly your tune file too...
    My knee jerk reaction is o2 sensor feedback (trailer hitching), but if you're open loop that aint it
    Mar 2009
    Could also be timing related, I believe in that area of the map you want to kind of flatline the timing to reduce cam surge.
  1. Very unusual RTACS issue
    By hquick in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 12th, 2009, 12:44 PM
  2. Replies: 26
    Last Post: May 29th, 2008, 07:25 AM
  3. PID Problem w/BBB - Asked by Cougar 281 (FRPDES problem)
    By Jasondt2001 in forum FlashScan V2 BB Logging
    Last Post: March 23rd, 2008, 02:02 PM
  4. LM-1 problem
    By robz in forum General
    Last Post: August 23rd, 2006, 07:53 AM
