Results 1 to 1 of 1
Thread: 2nd Gen Cruze Read shows incorrect info
    Jul 2012
    Default 2nd Gen Cruze Read shows incorrect info
    As title states i have a 2017 chevy cruze with the 1.6l diesel and a 6speed manual trans and E98 ecm. When i read the ecm under controller calibrations it lists that its an automatic. Equipment used to read vehicle was a flash scan v2 and v8 software via obd port. I do not believe this car has ever been modified and when i compare to gm sps info everything seems to match up. Is this just a bug?
    I have not licensed this controller yet and i have not attempted to flash it because I'm still trying to get everything figured out and teach myself what has to be done. Things have changed so much since i have done anything like this.
    I am also having trouble finding the OEM file as well as definitions and addresses associated with that 24000207 os, should i use a different compatible os? the lookup utility list 6 other os's 3 are 554 and 3 are 555 which seems way off considering my os is a 240.
    Any help would be appreciated or any guidance would be greatly appreciated.
Name:	efi live compatible os's.png
ID:	24904   Click image for larger version.
Name:	Cruze controller info efilive.png
ID:	24905   Click image for larger version.
Name:	controller details efi live.png
  1. Replies: 1
    Last Post: December 31st, 2024, 04:59 AM
  2. Possible unsupported TCM read 2013 Cruze
    By a78turbo in forum 6 speed/8 speed RWD/FWD Transmission Tuning (incl T43, T76, T87)
    Last Post: September 12th, 2014, 09:38 AM
  3. Unsupported Read 2013 Cruze
    By a78turbo in forum E78, E83, E84 PFI ECM's
    Last Post: March 5th, 2014, 02:26 PM
  4. Unsupported Read 2013 Cruze
    By a78turbo in forum E39, E80, E82 & E92 SIDI ECM's
  5. GEN lll v8 6 liter gas (NEED INFO ON SOME TUNING)
    By RAM PERFORMANCE in forum Gen III V8 Specific
    Last Post: January 21st, 2011, 09:40 AM
