Results 1 to 3 of 3
Thread: Reman 12200411 PCM flashing
    Jul 2010
    Default Reman 12200411 PCM flashing
    I have spent quite a bit of time searching but I've found mixed stuff. If I buy a reman 12200411 PCM that is likely blank, can I use EFILIVE to flash it with the initial calibration? Has anyone had any luck with these reman 12200411 PCM's? I know all of this stuff is quite old. Is there a better option now? I do have EFILIVE and i have a V2 and also a V3. Thanks for the help.
    Ive never seen a old LS1 PCM be blank.
    Unless they are using new chips and such.
    Give it a try and see what happens.
    Jul 2010
    Thank you for the reply.
  1. Swapping 12200411 PCM into 98 Chevy Truck
    By 350SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 28th, 2017, 01:05 AM
  2. Does the 12200411 PCM have Tow/Haul Capabilities?
    By A Low Dime in forum Vortec V6/V8 Specific
    Last Post: September 22nd, 2010, 03:13 PM
  3. Blank 12200411 PCM
    By joecar in forum Gen III V8 Specific
    Last Post: May 7th, 2007, 08:39 AM
