Results 1 to 10 of 19
Thread: LS1B Chopacabra cam Magnuson Super I feel like im drowning.
    Dec 2025
    Default LS1B Chopacabra cam Magnuson Super I feel like im drowning.
    I am struggling to get anywhere with the tunning this is my first time trying to tune a vehicle. I have read several forum posts and have figured out how to get the truck to idle but now it seems really fat on the tune and I don't seem to understand how to lean it out properly. I am willing to learn anything someone has to offer thanks in advance for your time and knowledge.
    05 GMC Yukon XL with a 6.0L
    Texas Speed Chopacabra Cam 214/222
    Delphi 42# injectors 58 PSI from fuel pump
    Magnuson Magna charger 8 PSI
    .020 over bore
    Here is a short log let me know if I have something out of place or need more data please.
    porter log 3.pldporter log 3.pld
    Post your tune
    Whats the part number on the injectors?
    Dec 2025
    The Injector Part # 25176061
    I did a study a tune LQ4 LSA that someone else posted and I tried to understand more which lead me to add a boost VE table and changing my main VE table here is the new tune and a data log from current tune. Thanks for your reply.6.0 SC 1.ctz6.0 sc log 1.pld
    Need to know what MAP sensor you have.
    Here is just a startup deal.
    Dec 2025
    Map sensor Part# 09359409 3 Bar
    Dec 2025
    Thank you I will be going over that file so I can try to understand more about the tunning side.
    Dec 2025
    I installed the tune hoping to get a log and it instantly popped.
    P0103 Mass Air Flow (MAF) Sensor Circuit High Permanent ($01) EPA-Perm, Supp
    I did capture a short log at idle if it helps.
    nonnieselman log.pld
    Quote Originally Posted by Built Tech View Post
    That is showing to be the factory 1 bar map..
    Dec 2025
    Thank you I see that now that you pointed it out. I looked at one on Amazon and it was the wrong information. Would you recommend a different map or will this one suffice?
    https://www.pcmofnc.com/2020/03/12/g...r-2-bar-3-bar/
    I would use the 2 bar on the top left in this picture. Its plenty for 8psi.
  1. Knock retard 'feel'
    By Cougar281 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 29th, 2022, 09:14 AM
  2. I feel like I am soooo close!!
    By willn in forum Gen III V8 Specific
    Last Post: September 24th, 2014, 04:06 PM
  3. why do shifts and shift times feel different when in SD?
    By 350SS in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: May 5th, 2008, 06:11 AM
  4. Replies: 19
    Last Post: May 20th, 2006, 03:26 PM
  5. TRAK CAM super rich?
    Last Post: May 1st, 2006, 12:43 PM
