Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Timing calculator?
    Lifetime Member Jim P's Avatar
    Nov 2019
    Timing calculators are worthless. Here is what they do…
    Person A says to Person B, “tell me to set timing at 1600rpms and 45mm3/stroke to 7 degrees before top dead center.”
    Person B says to Person A, “ok, set timing at 1600rpms and 45mm3/stroke to 7 degrees before top dead center…”
    Person A says “ok, I will set timing at 1600rpm and 45mm3/stroke to 7 degrees before top dead center”
    Nov 2019
    What is important and desired and not one single timing calculator will ever ever tell you is combustion shape and combustion phasing
    Jul 2026
    A timing calculator is a useful tool for measuring durations, adding or subtracting time, and calculating intervals between events. It is commonly used for work schedules, sports, project planning, and daily time management. This helps users organize tasks and improve efficiency.
    Just like time calculations save effort, Calcular Porcentaje makes percentage calculations simple and fast for everyday needs.
  1. timming
    By chance cobb in forum Cummins 5.9L
    Last Post: October 14th, 2012, 06:50 AM
  2. 40 Degrees max timming, i want more
    By fezz57 in forum Gen III V8 Specific
    Last Post: November 5th, 2011, 08:36 PM
  3. Shift timming
    By bdr2008 in forum Allison 5 & 6 Speed
    Last Post: February 17th, 2009, 02:19 AM
  4. Duramax timming
    By Rambo in forum Duramax LB7
    Last Post: April 7th, 2007, 08:23 PM
  5. retard timming for N.O.S. help please
    By RandyWS6 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 9th, 2005, 06:52 AM
