Results 1 to 1 of 1
Thread: Purge solenoid ignoring speed and airflow limits
    Apr 2010
    Default Purge solenoid ignoring speed and airflow limits
    While I was doing some idle tuning I noticed the purge solenoid was opening and adding unwanted air. For some reason only the min temp value B0501 is operational. Anything I set B0502 and B0503 seems to have no function which I need to prevent it from opening when stationary at idle. Has anyone come across this issue and found a workaround? I have tried a full flash and still no luck. Engine is an LQ4 with 1MB LS1B green & blue connector PCM. Running COS 3150003. The solenoid is definitely working as the temp parameter does control it.
Name:	Purge parameters.png
Name:	Purge trend.png
  1. DCFO Minimum idle airflow desired Coastdown speed
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: July 28th, 2015, 08:47 AM
  2. E67 Airflow/Boost Limits - CTS-V??
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: June 16th, 2012, 08:04 AM
  3. Curious about Allison 6 speed solenoid logging
    By Brian1 in forum Black Box Logging
    Last Post: October 20th, 2009, 01:15 PM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 11:07 AM
