Results 1 to 4 of 4
Thread: Inactive O2's? ls7.
    Aug 2025
    Default Inactive O2's? ls7.
    Hope someone can help with this. I'm working my way round Efi Live and have done a number of scans and also tried several tunes I've been helpfully provided with.
    The lambda's don't fire up, not a trace. I even replaced them with new one's. On just one occasion they lit up upon engine start and then switched off. The heater wires are live. Basically the car fire's up great but I can't get past a really lumpy idle that will stall if I rev the throttle. I can hear the air entering the TB but the fuel's not arriving on time. With DVT I can get a decent idle and also a decent throttle response.
    I've found the various lambda settings but am not sure if they're correct. Can anyone suggest 'settings' for a stock ls7 engine that should put me in the right zone please? Until I get the lambda's working I can't progress. It's as if I need to find the 'On' switch.
    Specs are, stock 'stand alone' engine, no CATS just a muffler on each bank. The lambda's are fitted into the end of a cast factory header just after the rear cylinder.
    ETA: Are there any PID's I should look at?
    What wire harness are you working with?
    Aug 2025
    Thank you. The harness is a standalone E38 loom from the US which I bought many years ago. It was for an Ultima GTR. It seems very good quality. I forget the brand.
    Aug 2025
    I've looked at the 02 logs. On the first startup the lambdas are at 450 mv or less before crashing downwards. If I'm correct this is very lean and off the scale for a narrow band sensor. I'm going to see if the short term fuel trims reveal anything. :-)
  1. HCI LS7 what to do first?
    By spy2520 in forum Gen IV V8 Specific
    Last Post: May 28th, 2017, 01:19 PM
  2. 2012 Cruze 1.4T DFCO inactive?
    By Dennis93TA in forum E39, E80, E82 & E92 SIDI ECM's
    Last Post: December 1st, 2013, 06:03 AM
  3. Tuning LS7
    By johnsZ06 in forum Gen IV V8 Specific
    Last Post: May 15th, 2009, 02:19 AM
  4. 2003 Ls7
    By jfpilla in forum Gen IV V8 Specific
    Last Post: May 25th, 2007, 12:33 AM
