Results 1 to 2 of 2
Thread: Purge solenoid ignoring speed and airflow limits
    Apr 2010
    Default Purge solenoid ignoring speed and airflow limits
    While I was doing some idle tuning I noticed the purge solenoid was opening and adding unwanted air. For some reason only the min temp value B0501 is operational. Anything I set B0502 and B0503 seems to have no function which I need to prevent it from opening when stationary at idle. Has anyone come across this issue and found a workaround? I have tried a full flash and still no luck. Engine is an LQ4 with 1MB LS1B green & blue connector PCM. Running COS 3150003. The solenoid is definitely working as the temp parameter does control it.
Name:	Purge parameters.png
Name:	Purge trend.png
    Jun 2026
    I found the debate on the purge solenoid that ignores speed and airflow limits fascinating! As someone who has dabbled in tuning and diagnostics, I understand how frustrating it is when systems fail to behave as intended. It is critical to consider how these components interact with overall engine performance; neglecting these restrictions might skew data and result in inefficiencies.
    LQ4 with 1MB LS1B sprunki game
  1. DCFO Minimum idle airflow desired Coastdown speed
    By The Alchemist in forum E37, E38 & E67 PFI ECM's
    Last Post: July 28th, 2015, 08:47 AM
  2. E67 Airflow/Boost Limits - CTS-V??
    By Meister in forum E37, E38 & E67 PFI ECM's
    Last Post: June 16th, 2012, 08:04 AM
  3. Curious about Allison 6 speed solenoid logging
    By Brian1 in forum Black Box Logging
    Last Post: October 20th, 2009, 01:15 PM
  4. Desired Idle Speed and Idle Airflow
    By Bowtieman in forum General (Petrol, Gas, Ethanol)
    Last Post: March 20th, 2006, 11:07 AM
