Results 1 to 3 of 3
Thread: LS2 motor with LS1 knock sensors?
    Redline Motorsports
    Guest
    Default LS2 motor with LS1 knock sensors?
    I am finally taking some time to get my TT 402 into my C5. The thing has been on the side burner since March.
    What is the best way to approach the knock sensors since they are different between the LS1 and LS2. Will the LS2 sensors work with some configuring or can you just redrill and tap for the LS1's.
    I know it has been discussed here somewhere but can't find it.
    Howard
    Lifetime Member SinisterSS's Avatar
    Sep 2003
    Lots of mostly good info on LS1Tech; search the PCM Diag & Tuning forum for LS2 knock sensor
    2009 Z06 LS7 / 2008 Sierra Denali AWD L92 6L80E
    Flashing control modules since 2001. 8-)
    Who needs a MAP sensor on a supercharged LS6 anyway.
    Oct 2005
    Most mount them (LS1 KS) on the side of the LS2 block IIRC
    2014 VF SV LS3 Maloo.
  1. No knock sensors???
    Last Post: July 9th, 2016, 07:28 AM
  2. Knock Sensors off
    By waterbug1999 in forum Gen III V8 Specific
    Last Post: September 12th, 2009, 03:12 PM
  3. desenitising knock sensors
    By 98SS2836 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 26th, 2006, 10:40 AM
  4. 98 knock sensors
    Last Post: June 10th, 2006, 10:12 AM
  5. LS2/LS7 Knock Sensors and LS1/6 PCM
    By bink in forum General (Petrol, Gas, Ethanol)
    Last Post: June 21st, 2005, 10:55 AM
