Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: Car feels really flat initially
    Oct 2004
    Default Car feels really flat initially
    On the first start of the day (cold start) the car feels really flat and limp initially.
    My initial thoughts were that it was related to the spark being retarded by the B5910 ECT Spark Table and the B5956 Multiplier Table.
    I basically set the Multiplier Table to all 0 so that essentially no spark would be pulled. This seemed to make little or no difference .
    So the question is: What else could it be?
    Cold start for me these days is about 15*C (60*F) so not really that cold.
    Andrew
    EFILive Crew
    Jan 2005
    Quote Originally Posted by Tordne
    Have you tried slipping a Viagra into the gas tank 30 minutes before cranking?
    But seriously, at what point does the beast feel plump and erect? And how long has this been going on? If it last more than 4 hours, I think you should call a doctor.
    Oct 2005
    Maybe down to bad atomisation of the charge due to cold intake tract which will tend to condense the charge rather than assist atomisation.
    Could be dirty injectors not making a nice spray, just squirting a pool of fuel into the port.
    2014 VF SV LS3 Maloo.
    Jun 2005
    Maybe because initial, cold start commands OL for a couple of minutes?
    Could it be too lean immediately after startup...?
    Oct 2004
    Maybe the Viagra is the trick
    I'll let my WB heat up for a long time before startup this morning so that I can accurately get the AFRs from cold start, usually I don't care.
    It doesn't last too long which is why I thought it must have been those ECT Spark tables. But those retard timing up to about 70*C odd. And it definitely doesn't last that long. So, I'm not really suspecting spark at this stage.
    Will post more lately
    Andrew
    EFILive Crew
    Aug 2005
    My thoughts. My truck runs a bit rich when cold and has very good throttle response, even with the light throttle I give it.
    Oct 2004
    OK so the winner would appear to be REAL LEAN. I marked a couple of points where it felt flat and the AFRs were around the 16.6:1 mark with a commanded AFR of approx. 14.7:1.
    I have another question as a result of this logging though. I logged a PID called "IAC - Warmed-up Airflow In Gear" (GM.IAC_WD_DMA). This has a value of approx 8 grams/s and gets decayed out gradually. I'm wondering if this added airflow could be causing the lean condition? And, which tables does this PID relate to (doesn't say in the "More info" pane)?
    Andrew
    EFILive Crew
    Jan 2005
    when did you start having this problem?
    Oct 2004
    Quite a while... I just thought I go about trying to fix it. Tune is otherwise pretty solid right now so I need something else to mess with
    Andrew
    EFILive Crew
  1. Car feels sluggish after MAF removal
    By Alex99 in forum Gen III V8 Specific
    Last Post: August 18th, 2009, 04:36 AM
  2. a little help with idle and flat spot
    By woody69 in forum General (Petrol, Gas, Ethanol)
    Last Post: January 24th, 2007, 12:15 PM
  3. Engine power falls flat about 4800-5000 to redline
    By red12secz28 in forum General (Petrol, Gas, Ethanol)
    Last Post: July 23rd, 2006, 02:11 PM
  4. Flat Spot Autotune
    By purrvert in forum General (Petrol, Gas, Ethanol)
    Last Post: February 19th, 2006, 11:01 PM
