Thread: Commanded Fuel When Cranking table difference
    Senior Member ArKay99's Avatar
    Apr 2004
    Default Commanded Fuel When Cranking table difference
    I had recently upgraded from 7.3.1 to 7.3.2. In 7.3.1 the Commanded Fuel When cranking table had several columns referencing 24X counts. In this latest version I only have a single column. OS is 12221588. I guess for a single 24X Count accessing AFR or EQ to ECT. Is this correct?
    Go:LPE 403, VaraRam, Haltech, PowerMax 100mm MAF, Tony Mamo ported FAST90/NW90, 160* stat, Kooks, TI's, DRM cutouts, Ripper, 4:10's, Tex OZ700, QA1's, Tony Mamo ported AFR 205's, 242/242 .610/.610 114LSA+2, Yella Terras, 42lb/hr Green tops, ASP UD pulley, 2 AMW catch cans
    Show: Euro tails & mrkrs, Z06 chromes/Pilots, 300Wx2 Bolt w/12" Sub,
    red calipers & black rear letters, Zaino.
    530 RWHP, 479 RWTQ
    Jun 2005
    Did you upgrade your OS? I know when I look at a '98 f-body vs an '02 f-body, the newer one only has the one column.
    Apr 2004
    Quote Originally Posted by SSpdDmon
    Yes I upgraded my OS, but not between EFILive versions. What I mean is, the same OS has different table definitions in the different EFILive releases, at least on my machine.
    530 RWHP, 479 RWTQ
    Jun 2005
    I would guess it was something that happened when you switched OS's, not software versions. Then again, you never know. Either way, I wouldn't be messing with this table. If you were going to adjust a table for a smoother start, I'd go with the cranking VE. I took 15~50% out of my friends' Cranking VE tables and they start right up hot or cold with their 232/234 cams. Just look at your VE once you tuned the lower end and make adjustments based off of that. Keep in mind though, cranking VE and Main/Back VE have very different RPM rows.
    Apr 2004
    Got it. I was just noodleing and came upon this difference.
    530 RWHP, 479 RWTQ
    Quote Originally Posted by ArKay99
    There is a mistake in the calibrations definition files (*.cal) for late model PCM operating systems that causes that table {B3604} to display with only one column instead of 17 columns from 0..16. It will be fixed in the next release.
  1. {B4206} Use O2 With Open Loop Commanded Fuel Table
    By joecar in forum General (Petrol, Gas, Ethanol)
    Last Post: September 7th, 2007, 03:56 AM
  2. AUTO VE BOOST TABLE ?? COMMANDED #'s
    Last Post: July 20th, 2006, 04:55 AM
  3. Testing difference in fuel economy....
    By thunder550 in forum General (Petrol, Gas, Ethanol)
    Last Post: May 22nd, 2006, 02:32 AM
  4. Commanded AFR vs Table B3647
    By DrX in forum General (Petrol, Gas, Ethanol)
    Last Post: November 18th, 2005, 04:11 PM
