Please use the attached document template when creating new documents or tutorials for EFILive.
Before any document or tutorial is released under the official EFILive "banner" it must be approved by EFILive. Please do not distribute any documents using EFILive's document format unless it is approved by EFILive.
There are four "fields" used in the document: Title, Author, Creation Date and Last Saved Date. Please change Title and Author using the File->Properties option in Word. Then after you have changed their values, right click on the fields in the document and select "Update field" to cause the fields to show the correct information. Alternatively, select the entire document using Ctrl+A, then press F9 to update all fields in the document.
The date fields will be updated automatically by Word.
To make the document template file (*.dot) to be available in Word, place it in the folder:
\Documents and Settings\<username>\Application data\Microsoft\Templates
where <username> is the name used to log on to windows.
To use the EFILive template, select File->New and choose the EFILive Blank Document template.
If there are any problems using this document template, please post in this thread.
