Results 1 to 4 of 4
Thread: quick gear change question
    Redline Motorsports
    Guest
    Default quick gear change question
    I just wanted to confirm something as I have had issues in the past with this.
    A4 F-body. gear change only (to 3.73's).
    If I go to the speedometer tab; enter the new gear do I have to reenter the tire size? Also once that is changed you still have to tell it to recalculate the shift points....correct.
    Can someone please confirm these steps?
    Howard
    Jun 2005
    Enter new gear ratio only (unless tire size has also changed).
    Click the recalculate button (circular arrows) to determine percentage change.
    Click the adjust button to automatically make the changes to the shift and torque converter tables. A new window pops up and asks if you wish to continue. Only do this once!
    Click the "save" button in the spedometer window to apply the changes to the cells below.
    That's all from memory, but I'm pretty sure it's right.
    Sep 2003
    Sounds right!!!!
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Redline Motorsports
    Guest
    Thanks for the clarification! It does get a bit confusing with all the steps. I know if you double click that last one all hell breaks loose!
  1. Quick Question
    By duramax07tmd in forum General (Diesel)
    Last Post: March 16th, 2010, 03:06 PM
  2. Driving A6 with gear change without tune questions?
    By beefcake in forum Gen IV V8 Specific
    Last Post: April 12th, 2009, 11:28 PM
  3. LBZ gear change
    By IdahoRob in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 28th, 2008, 02:25 PM
  4. Quick question about the BCM....
    By Loudmouth LS1 in forum Gen III V8 Specific
    Last Post: October 14th, 2007, 04:19 PM
  5. Quick OS question
    By ViolatorTA in forum General (Petrol, Gas, Ethanol)
    Last Post: February 12th, 2006, 12:45 PM
