Results 1 to 10 of 16
Thread: I try to do a crank relearn and it doesn't work
    Jun 2006
    Default I try to do a crank relearn and it doesn't work
    When I bring up the relearn screen and hit start. I raise the rpm up, but the rpm climbs all the way up to redline (7000 rpm) and doesn't stop at 5000 like the directions say it will. I've tried it several times and it hasn't worked. Any suggetsions would be great. Thanks, Brian
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    How fast are you bringing the RPM's up? You need to do it in a fairly quick manner.
    Jun 2006
    I was trying to spread the rpm rise over the 10 seconds so maybe that is my problem. I thaught I tried it fast once, but I may not have. I'll try that when I go home for lunch today. Thanks
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    Smile
    I went diggin in the helms....
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Apr 2004
    Here is the P1336 it mentions http://www.ls2.com/boggs/dtcs/DTC%20P1336.htm
    Jun 2006
    I think it does have that code stored. I tried to reset the codes and do it again, but the code comes back as soon as I turn the car on again after I reset the code. I know the code that comes up for the crank not being learned is not on the list of unacceptable codes in EFILive for the crank relearn. Thanks a lot, Brian
    Jun 2006
    I guess my next question is how do I reset that code so that I can perform the relearn before the code comes back. Thanks, Brian
    Oct 2003
    Here's an interesting one -- I'm having trouble getting the crank relearn to work on my 1998 Formula, because whenever I rev the throttle it picks up a false VSS signal!! If I keep blipping the throttle in neutral, I can get the car "moving" 30 MPH ... The car has ALWAYS done that, even when it was bone stock.
    Jul 2006
    Quote Originally Posted by CRU SS N
    I'm having the same problem on my new LS1 engine....arrgghhh.
    Richard
    Austin, TX
    2008 C6 Z51, NPP, 3LT, 6-speed
    Jan 2005
    I haven't done one in a while, but as a I recall, the PCM only shuts off the injectors for a split second. It will feel like a stumble and that's when you need to let off.
  1. crank relearn??
    By 2004gmc in forum Lounge
    Last Post: July 30th, 2021, 12:24 PM
  2. im having a problem with the crank relearn
    By whackem04 in forum General
    Last Post: December 17th, 2009, 05:53 AM
  3. E38 5.3 LMG Crank relearn
    By harascho in forum Gen IV V8 Specific
    Last Post: December 4th, 2008, 08:04 AM
  4. crank relearn
    Last Post: August 28th, 2008, 06:07 AM
  5. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
