Results 1 to 5 of 5
Thread: VIN does not change after Full Reflash
    Aug 2006
    Default VIN does not change after Full Reflash
    I've noticed when reflashing my 12200411 PCM from a 2001 Trans Am to a 2001 Express Van, the VIN does not transfer with the reflash. Can someone explain this?
    I also noticed that if I manually change the VIN, all the vehicle information follows. Where is this vehicles information coming from? Does the PCM have a database that retrieves this information?
    Sep 2003
    Full reflashes with EFILive preserve the vin and crank angle data i think there is an option to not have it do this and rewrite the vin but the program isnt in front of me at the moment.
    The vehicle information is know from the breakdown of the vin characters there is no database in the PCM Ross and Paul just know what vin digit corresponds to what type of vehicleinformation.
    In Fbodys the Y vin digit (and I am not sure of the place) is for MY 2000 IIRC
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Apr 2006
    It didnt keep my crank info or my vin when I upgraded even after it said it did... easy fix
    99 C5 6speed LS2 402ci DTE 3.90 diff w/hardened output shaft, FLP headers, No Cats, ZO6 mufflers, Haltech Cobra CAI, Ported Fast 90 and LS2 TB, 42 Delphi, ZO6 Maf, EFI-Live, LC-1 wideband, Comp XE-r 232/236 .598/.605 112+0 lsa, AFR 205 heads milled .036 w/ Cometic .045 gaskets, TR 7.4 pushrods, textrila clutch, ASP underdrive pully, 490rwhp/474rwtq [email protected] 1.59 60ft
    10.96 video
    in car vids
    10.9 runs
    Jan 2005
    You can set the VIN with the scan tool
    I just went through this the other day. I flashed it 3 or 4 times trying to get the VIN to change then remember all I had to do was change it with the scan tool.
  1. cant do full reflash???
    By Madspeed in forum Duramax LB7
    Last Post: April 28th, 2010, 12:46 PM
  2. full reflash
    By SGFastMax in forum Duramax LB7
    Last Post: June 13th, 2009, 10:56 AM
  3. Always a full reflash?
    By 1SlowHoe in forum General (Petrol, Gas, Ethanol)
    Last Post: April 28th, 2008, 04:05 AM
  4. Full Reflash
    By Chevy366 in forum Custom Operating Systems
    Last Post: October 24th, 2006, 07:20 AM
  5. Full reflash ?
    By QUICKSILVER2002 in forum General (Petrol, Gas, Ethanol)
    Last Post: February 2nd, 2006, 01:05 PM
