Results 1 to 10 of 10
Thread: Is it possible for me to fix Colum locked
    Sep 2003
    Default Is it possible for me to fix Colum locked
    Vettes with Flashscan if I used a tune that has this allready implemented
    EFILive - The Single version of the Truth
    Larry - HumpinSS
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    Wouldn't that be nice? The program is about the fifth attempt GM made to fix the pesky CL problem. I think it is fair to say it did not work either. About all that reprogram did was screw up some aftermarket tunes. It even locked some LS1 Edit guys out of their own tunes.
    PowrMax Performance
    100 mm PowrMAF
    I have seen post on CF about people still having cl issues after the lastest gm attempt. The best bet is jsut to buy the $50 aftermarket box.
    Sep 2003
    Does anybody have a file that allready has this implemented or the latest attempt for an 01
    Larry - HumpinSS
    Oct 2003
    I have a stock 03 Z06 tun with the fix in there but I do not know where or what it is ?
    Just ran a comparo with a stocker from the tun shelf and it shows no difference. GM trashed the modified tune on this car to do the CL fix.
    PowrMax Performance
    100 mm PowrMAF
    Sep 2005
    Quote Originally Posted by minytrker
    Stupid question, but would setting {G0801} "Column Lock Option" to No allow you to disable the column lock function? I have the column lock bypass, so I'm not real concerned about it. Just curious more than anything.
    Any yes, the latest fix is still causing problems. One reason why I have thrown out the latest recall notice.
    EFILive Distributor dfe1's Avatar
    Jan 2005
    The dealer installed "the fix" on my 01 about a year ago. I don't know what else was done, but the operating system was switched to a 2002 (don't have the number off hand, but last three digits are 358). I haven't had any problems until the other day when the driver info panel said "Service Column Lock". I disconnected the battery and that eliminated the problem. From what I can determine, part of the GM fix is to have the system fail unlocked instead of locked. I could still drive the car even with "Service column Lock" being displayed. Let me know if you want the file.
    Dave
    DigitalEFI- EFILive US Distributor
    [email protected]
    678/344-1590
    Default Not in the tune.....
    Quote Originally Posted by Bruce Melton
    I don't believe that it is in the tune...but, rather in the O/S...That's why you can't do a compare.....
    Chuck CoW
    Oct 2003
    Quote Originally Posted by Chuck CoW
    Chuck CoW
    Could well be, but as part of the process they sweep the tune.
    PowrMax Performance
    100 mm PowrMAF
    Default It's always that way....
    GM does not have the ability to "only" flash the tune....The O/S and the tune are flashed at once kind of like the EFI "full re write"
    GM can only do it like that....with the "correct vin" and tune/os downloaded directly from GM.....
    His tune had no chance....
    Stay Tuned,
    Chuck CoW
  1. I Locked PCM but now have new V2
    Last Post: September 16th, 2008, 01:13 PM
  2. locked ECM
    By duramaxdaddy29 in forum Duramax LB7
    Last Post: June 4th, 2008, 05:30 PM
  3. E40 ECM locked
    By LBZ_YFZ in forum Gen IV V8 Specific
    Last Post: April 4th, 2008, 01:37 PM
  4. Locked E40
    By Jakes4321 in forum Gen IV V8 Specific
    Last Post: March 22nd, 2008, 08:04 PM
  5. 98's (Locked)
    By 87gmc in forum General (Petrol, Gas, Ethanol)
    Last Post: August 3rd, 2005, 09:54 AM
