Originally Posted by Garry
Yes using it for both. Thats what I am asking. I never noticed it before on my old laptop but on this new one it seems to be getting worse.
There is a tread here some where about altering the calc for voltage offset using a "voltage offset spreadsheet".Originally Posted by minytrker
Mine was off with the std calc in EFI, after altering calc it matches perfectly.
Definatly trust the LM1 readout over EFI and make sure you do a free air calibration, preferably with sensor out of exhaust and engine running with a few revs so voltage from charging system is where it would be when logging .
Do you know what your voltage offset is? It’s extremely hard not to get a voltage offset between your WBO2 and Flashscan.
I setup my LC-1’d 2nd analogue output to push 2v no matter what the AFR is, on Flashscan that comes in at 1.97V so I use in my calculations to correct the voltage offset to get my correct AFR reading in Flashscan.
I posted how I fixed the voltage offset on this topic> http://forum.efilive.com/showthread.php?t=1530&page=3
Originally Posted by bK
Chassis by Holden
Engine by Chev
PCM modified by Flashscan
Cam by Comp Cams
That's a good suggestion! Maybe this should be added to the LC-1 install how-to ... .02V already can make a difference ... not much, but it's a way to trouble-shoot the install before you even get started with tuning ... if somebody comes up with - like 1V off of what it's supposed to be, I recon it's time to check the cabling ... Maybe though one should use the output that's supposed to be used later for the EFI input be set to a fixed value, that way any variances on the side of the LC-1 can be outruled ...Originally Posted by bK
