Results 11 to 20 of 34
Thread: No interface cable found
    Sep 2006
    Quote Originally Posted by Tordne
    From the Tune Tool what happens when the interface is connected to the computer and you go to the Help menu and choose FlashScan PCM Licensing?
    This should query the cable and tell you the used/free PCM slots etc.
    Also perhaps try setting the cable type in the Scan Tool to V1 and disable Scan All Cable Types
    Tordne, I chose the Flash PCM licensing from the tune tool. At first it said something about not being able to connect then I refreshed and everything came up as normal.
    How do I set the cable type to V1? I tried looking for it but could not find menu for that. I'll try and search for a way to do it in the mean time. Thanks.
    Chris
    Oct 2004
    EDIT: Screen shot in post below.
    Andrew
    EFILive Crew
    Sep 2006
    Tordne, it says I do not have access to the screenshot link you provided. Thanks.
    Chris
    Oct 2004
    OOPS, that was posted in a special thread . I'll reports below:
Name:	Andrew Jensen-17.png
    Andrew
    EFILive Crew
    Sep 2006
    BTW, this is what it showed on the summary screen last time I tried connecting.
    Summary
    Supported parameters available 287
    Validated modules available 9
    System readiness test (EPA) Incomplete
    Specifically monitored tests Not checked yet
    O2 sensors tests Not checked yet
    Diagnostic trouble codes Not checked yet
    History freeze frames Not checked yet
    Stream-Slow scan mode Supported
    Stream-Fast scan mode Supported
    Maximum dynamic packets 16
    PCM
    System Readiness Tests Results
    MIL Status MIL_OFF
    Number Of Emission-Related Trouble Codes N/A
    Misfire Monitoring Ready
    Fuel System Monitoring Ready
    Comprehensive Component Monitoring Ready
    Catalyst Ready
    Heated Catalyst Not Supported
    Evaporative Purge System Not Ready
    Secondary Air System Not Supported
    A/C System Refrigerant Not Supported
    Oxygen Sensor Ready
    Oxygen sensor Heater Ready
    EGR System Not Supported
    Specifically Monitored Systems Tests Results
    Oxygen Sensors Tests Results
    Diagnostic Trouble Codes
    History data
    Sep 2006
    So I change the controller ID and the Scan tool ID to what you have also?
    Oct 2004
    It maybe that the version of software I have is newer, so the screen may look different.
    All you should need to change is the preferred cable type, and uncheck the "Scan all cable types" box.
    Incidently.. Did you try the Help->PCM Licnesng in the Tune Tool at all?
    Andrew
    EFILive Crew
    Sep 2006
    Yeah, I tried the help- pcm licensing in the tune tool. Everything popped up as normal: the serial number, pcm licenses....
    BTW, the screen looks pretty much the same but I also have the controller ID and Scan tool ID just like you. My controller ID says $10 PCM and my Scan tool ID says $F1
    Oh yeah, preffered cable type was set to V1 but scan all cable types was checked. I'll try turning it off.
  9. #19
    Sep 2006
    sitting in the truck right now. Still not working. The OBD light is flashing on the interface but no USB light.
  10. #20
    Oct 2004
    Thats is just so weird... If the Scan Tool was able to read the interface the USB connectivity you would have to assume is probably OK.
    What sort of truck is it (year, make, model, motor etc? What Operating System? And do you know that it is a supported vehicle?
    Can you read the tune out with the Tune Tool?
    Andrew
    EFILive Crew
  1. V2 "No interface cable found"????? Why??
    Last Post: August 5th, 2008, 12:13 PM
  2. What module to get EFILive V1 Interface Cable Or?
    By JETNITRO in forum General (Petrol, Gas, Ethanol)
    Last Post: September 15th, 2006, 09:07 AM
  3. No interface cable message
    By LS1WV in forum General
    Last Post: February 17th, 2006, 12:17 AM
  4. Sudden "No Interface Cable Found" problem
    By mtnman in forum General
    Last Post: November 22nd, 2005, 05:26 PM
  5. No interface cable found
    By eboggs_jkvl in forum General
    Last Post: November 21st, 2005, 05:09 PM
