I should just add that there is a few ways that can be used to lock PCM's from being read out using the normal methods, some are easy to bypass, others are very hard, if not impossible. However, nothing can ever stop somebody pulling the FlashROM off the PCB and reading it out in an EPROM programmer!!. (not recommender for the casual user)Originally Posted by DebianDog
