Results 1 to 10 of 17
Thread: saving raw BIN files
    Feb 2005
    Default saving raw BIN files
    Is there a way to do it? I know it can read BIN but the only save option is TUN
    2001 Camaro SS
    EFILive Custom OS3
    EFILive Distributor dfe1's Avatar
    Jan 2005
    All you have to do is change the suffix from .tun to .bin in a Windows Explorer window. You'll get a message to the effect that changing may cause instability. However, if you're changing to a bin suffix to try to use the file with different software, you may have a problem. Most tuning software does some type of encription and the files may not be readable or writable. As an example, I opened an HPTuners bin file with LS1Edit by changing the suffix from bin the ls1. But when I saved it with Edit, HPTuner wouldn't open it because the file was saved with 513k bytes rather than 512. That was the first problem. Second problem was that when I opened the .ls1 file with a binary editor, it didn't look anything like the original bin file because of the encription. I haven't tried HPTuner/FlashScan compatability, so I can't say whether you'll run into the same situation.
    Feb 2005
    it's easy to change the suffix but I want to write a raw BIN without the encryption and extra information of the TUN file.
    2001 Camaro SS
    EFILive Custom OS3
    Feb 2005
    somehow I got a brilliant idea and read the manual. page 15 says that saving in bin format is not supported. Is this a feature that will be implemented in the future??
    2001 Camaro SS
    EFILive Custom OS3
    Mar 2004
    You can load BIN files in to a PCM with flashscan , but you can only save them as TUN files as flashscan has encription . As every body knows what the work encription means and we live in the year 2005 so i am saw you will understand why it is there . The only way i could see how you could turn a TUN file in to a BIN is PM blacky and see if he would change it for you
    The *.tun files contain a *lot* more data than just the 512Kb or 1Mb flash image. We also store a lot of meta data such as comments, modification history and other meta data.
    EFILive could easily save a plain bin file. However, we deliberately do not support that because it makes it too easy for others to copy/reverse engineer our years of hard work.
    You can convert *.tun files to *.bin files or even *.ls1 files if you have access to the respective packages.
    Just program your PCM with EFILive's *.tun file, then re-read it using the package of your choice.
    We will also convert "one offs" for our customers if required. Send your *.tun file to me at paul@efilive.com and I'll send you back a *.bin file. All comments and other meta data will be removed.
    Feb 2005
    Blacky, I can understand you wanting to protect your development investment but what is the difference if you can upload the .TUN to a PCM, pull it off with HPTuner and obtain a .BIN that way. It seems that you have just made it difficult for the end user who invested in your software but really done nothing to prevent someone determined to reverse engineer what your code does.
    2001 Camaro SS
    EFILive Custom OS3
    Quote Originally Posted by TTExpreSS
    Why would you want to look at it in a .bin format ? , it was done that way so that all the extra stuff can be included in the file , it makes it so much easier to tune when all the history etc is included.
    The only reason i can see anyone wanting to look at a bin file is for reverse engineeering , yes it doesnt stop it but it makes the process harder.
    Why do you want it in .bin format ?
    Until we are aware of a valid reason for saving a calibration as a plain bin file then we consider that being able to save a bin file is not necessary and does not disadvantage our customers.
    Our view is this: If someone really wants to reverse engineer EFILive by reflashing and uploading the calibration to/from a PCM each time a calibration is changed it will take orders of magnitude longer than if they could make changes and view the bin file immediately. That buys as time to keep ahead of the "wanna be's" snapping at our heels.
    We are not trying to stop the established tuners from reversing our product - they don't need to reverse ours and we don't need to reverse theirs. However, we are deliberately making it more difficult for new player(s) from stealing our IP, unfortunately that is part of this business.
    Maybe its a good time to find out why anyone would want to save their calibration as a plain bin file? Does anyone have a valid reason to be able to do that?
    Feb 2005
    my reason is so I can easily share my tune with others that use HPT. It aint the end of the world for me if .BIN writing is never supported. I understand your need to protect IP but we can read their BINS (very helpful to me) and not give back.
    2001 Camaro SS
    EFILive Custom OS3
  1. sd card saving???
    By 2004gmc in forum Lounge
    Last Post: May 9th, 2009, 03:18 AM
  2. Saving ECM/TCM Files
    By Cougar281 in forum General
    Last Post: July 17th, 2006, 11:37 PM
  3. Saving Maps?
    By carneb in forum General
    Last Post: June 30th, 2006, 12:57 PM
  4. Saving LTFT's with a data log...?
    By joecar in forum General
    Last Post: February 9th, 2006, 10:16 PM
