Thread: TPS reset
    Aug 2005
    Default TPS reset
    I have noticed that when my car is idling the throttle position is 0.4% which is causing issues with my idle. I think with the TPS reading 0.4% the car thinks the pedal has been depressed so then the car isn't using the idle tables anymore. I have done the TPS reset. (unplug the TPS, turn key on for about a minute, then plug the TPS back in) With the car not running the TPS reads 0% but when I start it it reads 0.4%. I have filed the holes in the TPS to give me more adjustment.
    Is there any setting in EFILive that I can change to say anytime the TPS is less than 1% then the PCM should think the car is idling? If not then what are your suggestions for me?
    John
    2000 SS Camaro
    LSX 427 with GT55-94mm
    9.77 @ 157 4030 lbs race weight
    Member TuneMaster's Avatar
    I have seen several TPS's read 0.4% before. Try setting B0108 to 0.5% and see how you go.
    Redline Motorsports
    Guest
    I don't think thats really a problem. The TPS's are auto adjusted, to some degree, and the PCM has a certain window of percentage that it associates with idle. What kind of idle problem are you having?
    Howard
    Jan 2005
    mine frequently jumps between 0-0.4% with no ill side effect on idle.
    Jun 2005
    The only other thing you can do is drill the hole in the throttle body blade so it's a little bigger. Then, close the blade with the set screw some.
    Sep 2003
    John mine sees anywhere from .4-1.8 when idling
    EFILive - The Single version of the Truth
    Larry - HumpinSS
  1. Reset Tap Cells
    By jaydog in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 23rd, 2009, 08:05 PM
  2. Little Help with VIN reset after RR install
    By Whippled 496 in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 15th, 2008, 03:56 AM
  3. Reset DTCs
    By Chevy366 in forum FlashScan V2
    Last Post: November 16th, 2007, 01:31 PM
  4. Throttle Reset
    By RevGTO in forum General (Petrol, Gas, Ethanol)
    Last Post: January 27th, 2007, 05:27 AM
