Results 21 to 30 of 46
Thread: Problems with CKP relearn on 2001 12200411 PCM
  1. #21
    Aug 2006
    Quote Originally Posted by ChipsByAl
    Has the code P1345 ran and passed? If the correlation is incorrect between the cam sensor and the crank sensor the learn procedure won't run. The specification is + or - 2 degrees.
    AL
    For some reason P1345 was not set when I reflashed the PCM and started the engine. I had a generator code and a MIL circuit (service engine light) code P0650.
  2. #22
    Sep 2006
    Any progress on the relearn process? Any more problems pop up?
    Thanks,
    Ron
  3. #23
    Aug 2006
    Quote Originally Posted by scuzz
    Thanks,
    Ron
    I haven't touched it since I last posted. The control panel is now attached to a VW Bug engine running with a GM TBI unit. I probably won't be able to look at the engine again until Spring.
  4. #24
    Sep 2006
    How's the bug running with a TBI? That's kool!
    I built VW engines for 18 years, and I have a 59 Karhman Ghia I've been thinking about building. The dual webers might have to be replaced with a TBI.
    Need more info.
    Thanks,
    Ron
  5. #25
    Aug 2006
    Need more info.
    Thanks,
    Ron
    It was a kit purchased about 8 years ago from Turbo City. It runs on a 1227747 ECM.
  6. #26
    Sep 2006
    That's cool. I'd like to come across one of those that no one has used for a while.
  7. #27
    Aug 2006
    I am having the exact same relearn problem on the same 12200411 PCM. What I am wondering is in post 15 Joecars' 3rd document shows that the low/rev clutch is engaged in park but not in neutral, so maybe this PCM wants to be in neutral? Just a thought. I am going to try again today in neutral. I have been over the wiring diagrams about 40 times and I don't see any mistakes on my part.
  8. #28
    Sep 2006
    It'd be nice to resolve all these problems before I fire my truck in a couple weeks.
    Good luck Lextech.
    Ron
  9. #29
    Aug 2006
    Finally got the crank relearn figured out. I did the relearn today. My 12200411 is programed as an 01 Express van 5.7-4l80e. This programming wants to see 4 inputs from the Park/Neutral switch. I grounded pin 32 and 34 of C1 Blue 80pin connector DURING the relearn, so the PCM thinks it's in park. I will properly wire it later, but my harness is all finished and tidy and I don't want to open it up any time soon. My emission test is this month. I am going to go on Monday and give it a try.
  10. #30
    Sep 2006
    Lextech, what did you use to do the re-learn with?
    Thanks,
    Ron
  1. Does the 12200411 PCM have Tow/Haul Capabilities?
    By A Low Dime in forum Vortec V6/V8 Specific
    Last Post: September 22nd, 2010, 03:13 PM
  2. 12200411 Injectors 50#
    By GMjohn in forum Gen III V8 Specific
    Last Post: March 7th, 2008, 07:03 PM
  3. Blank 12200411 PCM
    By joecar in forum Gen III V8 Specific
    Last Post: May 7th, 2007, 08:39 AM
