Results 1 to 10 of 10
Thread: Opps, Need Emission Test
    Jul 2005
    Default Opps, Need Emission Test
    Our county has done away with emission tests as of 1 Jan 07, and of course I need one in Nov to re-register my '02 Vette.
    Here is the problem; I am running twin turbos, bigger injectors, Custom OS and AutoVE tune with MAF disabled according to tutorials posted in EFILive.
    What will I have to do to pass emissions test? I think this test will just plug into the OBDII connector to test emissions.
    Options:
    1. Should I load a stock tune and OS, rescale the injectors, drive carefully to stay out of boost, go get emissions tested, pass, reload current tune and OS and be happy. Will this work?
    2. Turn off the NO MILs that were turned off in the Custom OS Tutorial, be careful to stay out of boost, get emissions tested, pass, turn the NO MILs back on and be happy. Will this work?
    3. Other suggestions?
    Lonnie
    2002 EB Coupe, MN6
    Xtreme TTi Twins @8psi, Dual A-pilar gauges - fuel&boost, x-pipe, Borla Straight Twin Oval from Cats on back, Hurst Short Throw, CCW 3 piece rims - 18x9.5/275-35 and 18x11.5/335-30 Pilot Sports
    Drive it like you stole it!!!!!
    Duplicate post... which one do you want me to delete...?
    I'll delete the one with the least view count later this morning.
    Edit: ok, this instance is the winner (16:6).
    Jun 2006
    3. de-register your car after Nov 30th and re-register in January?
    Lifetime Member emarkay's Avatar
    If you have a visual inspect, you are toast.
    Why don't you see what your DMV is really going to use, what procedure and then plan ahead.
    If they hook up to the OBDII port, all readiness tests better be OK or automatic fail that time. Also, depending on what the rules are in your state you may be denied a registration, so play this one with care.
    MRK
    PS: option 4: Do what I did and move to where there are NO inspections!
    Jan 2005
    If you have alternate transportation, I would let it slide until next year.
    Yup, just show up late and tell them the car was broken and/or you were out of town...
    Or, if you fail the test, can you get them to give you a temporary waiver (or something)...?
    Senior Member VortechC5's Avatar
    Jun 2003
    The emissions test in El Paso county is a no brainer. They only do a tailpipe test at idle and at 2500 rpm. They do not connect to the car at all. My car easily passed with my heads, cam, headers, cats, etc.
    Mark
    02 C5 Coupe - LS7, TSP 265 LS7 heads, ARH, Z06 cat-back, HREs, 3.73 gears, Wilwood brakes, DeWitts radiator
    15 C7 Z5 1 Coupe - stock for now
    12 Avalanche - tune, Corsa Touring
    Jul 2005
    Thanks Mark. This should be interesting. I am running leaner than stock almost all over the RPM/MAP range except in boost, which will not affect the emissions test. I will go down this Saturday and give it a go.
    More to come.....
    Lonnie
    2002 EB Coupe, MN6
    Jun 2006
    Good Luck!
    Jun 2003
    Good luck with the e-test. As long as you are not lean enough to be into lean misfire I think that you'll be fine.
    Mark
    Quote Originally Posted by lplott
    More to come.....
    Lonnie
  1. Emission Testing/Ways to Cheat?
    By onegonewild in forum Gen III V8 Specific
    Last Post: July 13th, 2009, 07:08 AM
  2. need some help emission related
    By 98SS2836 in forum General (Petrol, Gas, Ethanol)
    Last Post: June 1st, 2007, 04:32 AM
  3. I got it... Opps I aint got it...
    By MN C5 in forum Custom Operating Systems
    Last Post: December 28th, 2005, 04:27 AM
  4. Custom OS and OBD2 emission testing
    By mistermike in forum General (Petrol, Gas, Ethanol)
    Last Post: May 17th, 2005, 02:10 PM
