Results 1 to 9 of 9
Thread: Math needed for gms/sec vs lbs/minute
    Default Math needed for gms/sec vs lbs/minute
    I have been crunching numbers all night with an experiment and can't seem to get gms/sec converter to lbs/minute and vice versa. What is the conversion?
    Howard
    www.redline-motorsports.net
    1-954-703-5560
    2006 ZO6 895/866 with APS TT
    2011 HTR-850R Camaro
    Oct 2005
    g/s to lb/min: multiply by .1322
    lb/min to g/s: divide by .1322
    g/s to lb/hr: multiply by 7.93
    lb/hr to g/s: divide by 7.93
    2017 Camaro SS, 2014 Ram 2500 4x4 Cummins 6.7L, 2004 Chevy Avalanche Z71 4̶X̶4̶(now 2WD), 5870lb race weight, 10.93@ 124, Twin TVS1900s, Twin Throttle, 429 LSX, 4L80E, custom 14 bolt rear, V2, R̶o̶a̶d̶R̶u̶n̶n̶e̶r̶(dead), COS3......
    Gettin' the Groceries
    Use the built in converter in EFILive's Tuning Tool.
    See screenshot.
    See screenshot.
    Paul,
    Can the conversion tool also convert between AFR, EQ, Lambda...?
    Joe
    I figured it was right under my nose!
    Since a motor ingests the most amount of air that it can at the highest VE (peak torque), why can't you evaluate lbs/minute as a tool to determine an engines peak air capacity?
    Actually.............i think I just answered my own question.....................the engine is nothing more then a glorified air pump. The volume of air will be the same regardless of fuel and timing..........................
    I guess if you baseline a car prior to mods and it moves 52 lbs/min and after mods its 62 lbs/min, it is going to make more power.
    What happens when rescaling the MAF now........I assume the stock GM MAF calibration is acurate.
    Howard
    1-954-703-5560
    Quote Originally Posted by Redline Motorsports
    ...I guess if you baseline a car prior to mods and it moves 52 lbs/min and after mods its 62 lbs/min, it is going to make more power...
    That's the key, and also the mass per cylinder (g/cyl) value will be higher.
    Jul 2005
    redline: read this, it shows you exactly how airflow is related to ve
    http://redhardsupra.blogspot.com/200...ity-works.html
    Paul,
    Joe
    Yes, but it would require an extra inout field to specify stoich. Usually 14.7 for gas (in most GM cals it is 14.63) but it will be different for different fuels.
    But it could be easily added and would be useful.
    EFILive Distributor Trippin's Avatar
    May 2004
    Howard
    In most cases yes but just be careful, you could get into a situation where it moves more air and makes less power.
    Typically with to much exhaust event. The combination of an early exhaust valve opening and a good flowing exhaust port could effectively blow the cylinder down to quickly and move more air through the engine, however not use any of it to push the piston down.
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
  1. WB Volts vs. AFR math needed!
    By Redline Motorsports in forum General
    Last Post: March 12th, 2009, 04:54 AM
  2. Math for the VE multiplier
    By Beer99C5 in forum Custom Operating Systems
    Last Post: September 8th, 2007, 01:56 AM
  3. Paris: the 9 minute tour
    By joecar in forum Lounge
    Last Post: October 13th, 2006, 05:36 AM
  4. Can Black Box Logs Be Longer Than 1 Minute???
    By CTP Racing in forum General (Petrol, Gas, Ethanol)
    Last Post: September 29th, 2006, 05:41 AM
  5. Math ?
    By johnsZ06 in forum General (Petrol, Gas, Ethanol)
    Last Post: November 9th, 2005, 02:00 AM
