Thread: The new script feature
    Sep 2003
    Default The new script feature
    is the shit. That was a very good idea and will save a lot of time espcially on DTC and MILS. Kudos to the EFILive crew for thinking tat one up.
    What other neat tricks were added in this release
    You can thank wait4me for that one. It was his idea
    Bringing this one back also. I'm new to EFILive, but not new to tuning. The script feature is absolutely awesome! It makes life so much easier.
    Aaron
    '03 Z06 Corvette - The normal stuff...
    EFI-101, EFI Advanced, EFILive-101
    EFI University Evangelist
    Lifetime Member macca_779's Avatar
    Jan 2007
    What kinds of things have guys been using it for. I've never used it.
    It's an automated way of modifying anything you do to a tune file. Here's an example that I wrote a few days ago. This script modifies all of the injector tables to the accommodate the Bosch 36 lb ASA/GTP injectors. It's much easier to do it this way than copy/paste manually.
    Aaron
    Jan 2007
    Hey Aaron,
    thanks for all the scripts.
    Could I ask you to do one for the Bosch 42lb injectors?
    Howard
    DUCT TAPE.
    98 K1500 'HOLDEN' Suburban.
  1. Script help!
    By speedygoss in forum Duramax LLY
    Last Post: March 6th, 2011, 06:20 AM
  2. LBz to LMM script
    By terryr85 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: May 7th, 2010, 02:04 AM
  3. Script ?
    By GAMEOVER in forum General (Petrol, Gas, Ethanol)
    Last Post: January 1st, 2009, 06:46 PM
  4. Script feature comments function
    By 405HP_Z06 in forum Tutorials
    Last Post: June 2nd, 2008, 12:02 PM
  5. Script help
    Last Post: February 27th, 2006, 03:07 PM
