Page 1 of 4 123 ... LastLast
Results 1 to 10 of 33
Thread: CKP Relearn
    Oct 2006
    Default CKP Relearn
    On the way back from the store, check engine light came on. Scanned with EFILive and got the CKP Relearn code, tried to relearn with EFILive and no success.
    Rey
    Oct 2004
    Any errors or symptoms that you can pass on?
    I've never done it, byt from what I recall reading there are some pretty strick requirements to perform the procedure.
    Also, are you running the latest available build of the software? I recall an update from this a while back as well if I recall correctly.
    Andrew
    EFILive Crew
    Oct 2006
    I'm using version 7.3.3 with flashscan version 2. Followed directions according to the manual. The injectors don't cut out like the manual states. Tried multiple times. There is no errors when doing the relearn.
    Rey
    Oct 2004
    Hmm.. Will wait for someone else to chime in then, maybe it is a V2 thing.
    Andrew
    EFILive Crew
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    I did it last summer with V1 and it worked. You have to rev it pretty high as I remember.
    PowrMax Performance
    100 mm PowrMAF
    Lifetime Member eboggs_jkvl's Avatar
    Apr 2004
    I think the deceleration they are referring to is hitting the rev limiter.
    2014 Corvette Convertible, Torch Red, A6, Z51, 3LT, NPP Exhaust
    Oct 2006
    I tried pretty much everything, hitting the rev limiter. How long do I have to let the engine idle after revving the engine before shutting off?
    Rey
    Are you applying the brakes during the procedure..?
    Is the PCM seeing the brake switch state bit...?
    Oct 2006
    I applied the brakes, is there anyway to view the brake switch thru EFILive?
  1. CKP Relearn
    By 91LS1S10 in forum Gen III V8 Specific
    Last Post: January 17th, 2009, 07:03 PM
  2. Cant perform relearn..help
    By slow89irocz in forum FlashScan V1
    Last Post: October 16th, 2008, 03:08 PM
  3. tps wont relearn
    By mtwolff in forum Gen III V8 Specific
    Last Post: October 10th, 2008, 09:35 PM
  4. crank relearn
    Last Post: August 28th, 2008, 06:07 AM
  5. Crank Relearn
    By mk6racer in forum Gen III V8 Specific
    Last Post: May 15th, 2008, 11:05 AM
