Hi Dennis,
EFILive is a few days away (maybe a week or two at the latest) from releasing our 2-bar support.
2-bar support is speed-density only, you are required to remove (or disconnect) the MAF.
There are two versions of 2-bar support in EFILive:
1. Personal, which runs the PCM in speed density mode using only the low octane spark map with no knock control.
2. Commercial, which runs the full twin spark map with full adaptive knock control.
The Personal version requires only calibration changes, the Commercial version requires a full re-flash to convert some parts of the PCM's operating system to EFILive's customizations.
The Commercial version of EFILive costs an extra USD $150 on top of the purchase price of the Personal version. However, if you can find someone who can safely perform a full re-flash of your PCM then you can flash in our (free) customized 2-bar operating system and continue to tune it with just the Personal version. The Commercial version is only required for the initial full re-flash.
The 2-bar calibration supplied by EFILive will have all the necessary calibration changes already done, including the MAF trouble codes and MAP rescaling. You will just need to tweak it to suit your engine/SC characteristics.
You may purchase EFILive Personal Scan and Tune here:
http://store.efilive.com/index.asp?P...WPROD&ProdID=4
Paul Blackmore
