Results 1 to 5 of 5
Thread: Calculated PID Problem
    Senior Member NewV's Avatar
    Nov 2006
    Default Calculated PID Problem
    I'm trying to add a PID to convert cylinder grams to ounces so I can use it like its displayed in the tuning tool. With the following calc_pids.txt file I get errors starting scan related to cylairoz not defined. Anybody know what I'm doing wrong here?
    # File details
    # This section defines various details about the file format.
    *FILE
    #Parameter Value Description
    VERSION 7.1.1 File version
    DECSEP . Decimal separator used in this file
    # Units
    #Code System Abbr Description
    None None "" "No units"
    cylairoz None oz/Cyl "Ounces per cylinder"
    # Add slot definitions here
    *CLC-00-600
    cylairoz 0.008 0.042 .3 "{GM.CYLAIR_DMA}*28.35"
    CALC.CYLAIROZ F600 CLC-00-600 "cylairoz" Air "Oz/Cylinder"
    2005 CTS-V w/tuner wannabe driver
    Jun 2005
    Why not just change the tuner to grams/cylinder? Here's how you change between units:
    http://forum.efilive.com/showthread....light=bullseye
    Most of us use metric for anything other than speed or temperature (and sometimes displacement). In order for us to help you easier, it might be a good idea to get used to kPa & grams/second instead of inHg and lbs/minute. Just my $0.02...
    Nov 2006
    SSpdDmon - great point, I should have thought of that.
    Quote Originally Posted by NewV
    Code:
    # Units
    *UNITS
    You're missing the *UNITS section header.
    Paul, good eye.
  1. Formula help for Calculated Pid
    By vetteboy2k in forum Black Box Logging
    Last Post: December 21st, 2012, 10:16 PM
  2. Calculated PID's
    By Jason S. in forum General (Petrol, Gas, Ethanol)
    Last Post: March 17th, 2007, 09:55 AM
  3. LM1 Calculated AFR PID
    By VetPet in forum General (Petrol, Gas, Ethanol)
    Last Post: September 3rd, 2006, 03:04 AM
  4. Can't get calculated PID to work for MPG
    By PSWired in forum General
    Last Post: August 7th, 2005, 07:29 AM
