What are the best PIDs to log for timing and what tables in the tune file are they best compared to when reviewing logs?
I have added 2-3 degrees timing but having a tough time seeing it in the logs. The car feels different so I know the timing is in there but the actual logged values seem to change very little. I have added to the High and Low octane tables.
Also how much timing is too much?
Should you add till knock appears?
