Code:
# File details
# This section defines various details about the file format.
*FILE
#Parameter Value Description
VERSION 7.1.1 File version
DECSEP . Decimal separator used in this file
# Units
*UNITS
#Code System Abbr Description
mgpc Metric mg/cyl "Milligrams per cylinder"
# Add slot definitions here
*CLC-00-000
mgpc 0.0 2000.0 .0 "{GM.DYNCYLAIR_DMA}*1000"
CALC.DYNCYLAIR_MG F500 CLC-00-000 mgpc Tune "Air Flow Milligrams/Cyl - Speed Density"
