Download links:
http://download.efilive.com/software...75_605_555.zip (94Mb)
http://download.efilive.com/software...75_605_555.md5
Please read the Readme.rtf file before installing the main release. It recommends that you uninstall V7.3.2 prior to installing V7.3.3. If you have already uninstalled V7.3.2 and installed V7.3.3, then you may just install this "Update 2" over the top of the original V7.3.3 installation without uninstalling it first.
This new software requires firmware: V2.04.47 or later. Please make sure you upgrade the firmware in your FlashScan V2 device.
The FlashScan Firmware Programmer can be found on the Windows Start menu: Start->All Programs->EFILive V7->Update FlashScan V2 Firmware.
The FlashScan firmware image is installed here: \Program Files\EFILive\V7\FSProg_V2_4_47.ffw.
New Tuning Tool Features in V7.3.3
Nov 10, 2006Nov 25, 2006 (Update 1)
- Added CAN based, LS2 (E40) logging, reading and flashing.
- Added support for FlashScan V2 interface cable.
Dec 17, 2006 (Update 2)
- Script files can now be created automatically based on the differences between two files.
- Help->FlashScan V2 PCM licensing... renamed to: Help->FlashScan V2 VIN licensing...
- The 3D rotation button now animates the pre-set rotations. (It no longer saves *.bmp files into the V7 executable folder).
- Fixed range error when unlock key was greater than 65535.
- Added the "follow" option to bins folder. The last bin folder accessed can now be remembered. The option is selected by double clicking the Bins entry, in the Folders tab page of the Scan Tool Properties window.
- Fixed potential failure of E40 full flash with updated bootloader.
- Added controller pictures. Selecting different controllers in the Read, Flash or Lock windows will display a picture of the selected controller.
- Added option to upgrade from "V2 Scan Only" to "V2 Scan and Tune" in the EFILive software and FlashScan Firmware (V2.04.39).
- Added option to bypass V1->V2 upgrade requirements in FlashScan Firmware (V2.04.40).
- Reduced PCM read timeout from 10 seconds to 4 seconds to prevent keep-alive message (5 second cycle) from expiring.
- Prevented unsupported DMA PIDs from being used in BB logging. This also fixes the "RPM not logging correctly" problem.
- Gen-IV VE tables are now displayed in the same units as Gen-III VE tables (i.e. Grams*Kelvin/kPa and optionally %VE).
- Updated speed->gear-rpm conversion display in status bar to include 6 gears.
- 5 speed auto (T42) cals have been added (these cals will be updated with trans pressure tables in the next release).
- Fixed V2 install manuals that incorrectly referenced V1 instead of V2.
Dec 23, 2006 (Update 3)
- FlashScan interface type and controller protocols are checked prior to reading or flashing a controller to make sure the correct interface is in use for the attached controller.
- Fixed the fault that caused EFILive to erase the serial number during a full flash.
- When EFILive full flashes a controller with a blank serial number, it will now generate a pseudo random serial number and program it back into the controller. That allows subsequent calibration only reflash operations to correctly license the controller.
- Added LBZ Duramax tuning support.
- Added new calibrations for LS1.
- Added new calibrations for LS2.
- Added 97/98 support for RoadRunner devices.
New Scan Tool Features in V7.3.3
- Added new calibrations for LBZ.
- Fixed PID validation for vehicles with separate engine and trans controllers.
- Added LL8 and L52 in Customer details window (Displacement option).
- Added 6 speed trans selection in Customer details window (Trans option).
- Operating System list in the "Change VIN" window is now populated correctly.
- Fixed VIN, OS and Trans being ignored when loading log files.
- Added option to allow log files to be cleared without prompting for a filename.
- The controller type must now be specified when connecting the Scan Tool to a vehicle.
- Added new DMA PIDs for LS2.
- Added LBZ Duramax scanning support.
- Added support for scanning DMA PIDs for LBZ.
- Added DMA PIDs for LBZ.
