Page 1 of 3 123 LastLast
Results 1 to 10 of 23
Thread: EFILive V7.3.3 Software Release - Updated Dec 23, 2006
    Default EFILive V7.3.3 Software Release - Updated Dec 23, 2006
    Download links:
    http://download.efilive.com/software...75_605_555.zip (94Mb)
    http://download.efilive.com/software...75_605_555.md5
    Please read the Readme.rtf file before installing the main release. It recommends that you uninstall V7.3.2 prior to installing V7.3.3. If you have already uninstalled V7.3.2 and installed V7.3.3, then you may just install this "Update 2" over the top of the original V7.3.3 installation without uninstalling it first.
    This new software requires firmware: V2.04.47 or later. Please make sure you upgrade the firmware in your FlashScan V2 device.
    The FlashScan Firmware Programmer can be found on the Windows Start menu: Start->All Programs->EFILive V7->Update FlashScan V2 Firmware.
    The FlashScan firmware image is installed here: \Program Files\EFILive\V7\FSProg_V2_4_47.ffw.
    New Tuning Tool Features in V7.3.3
    Nov 10, 2006
    • Added CAN based, LS2 (E40) logging, reading and flashing.
    • Added support for FlashScan V2 interface cable.
    Nov 25, 2006 (Update 1)
    • Script files can now be created automatically based on the differences between two files.
    • Help->FlashScan V2 PCM licensing... renamed to: Help->FlashScan V2 VIN licensing...
    • The 3D rotation button now animates the pre-set rotations. (It no longer saves *.bmp files into the V7 executable folder).
    • Fixed range error when unlock key was greater than 65535.
    • Added the "follow" option to bins folder. The last bin folder accessed can now be remembered. The option is selected by double clicking the Bins entry, in the Folders tab page of the Scan Tool Properties window.
    • Fixed potential failure of E40 full flash with updated bootloader.
    • Added controller pictures. Selecting different controllers in the Read, Flash or Lock windows will display a picture of the selected controller.
    • Added option to upgrade from "V2 Scan Only" to "V2 Scan and Tune" in the EFILive software and FlashScan Firmware (V2.04.39).
    • Added option to bypass V1->V2 upgrade requirements in FlashScan Firmware (V2.04.40).
    • Reduced PCM read timeout from 10 seconds to 4 seconds to prevent keep-alive message (5 second cycle) from expiring.
    • Prevented unsupported DMA PIDs from being used in BB logging. This also fixes the "RPM not logging correctly" problem.
    • Gen-IV VE tables are now displayed in the same units as Gen-III VE tables (i.e. Grams*Kelvin/kPa and optionally %VE).
    • Updated speed->gear-rpm conversion display in status bar to include 6 gears.
    • 5 speed auto (T42) cals have been added (these cals will be updated with trans pressure tables in the next release).
    • Fixed V2 install manuals that incorrectly referenced V1 instead of V2.
    Dec 17, 2006 (Update 2)
    • FlashScan interface type and controller protocols are checked prior to reading or flashing a controller to make sure the correct interface is in use for the attached controller.
    • Fixed the fault that caused EFILive to erase the serial number during a full flash.
    • When EFILive full flashes a controller with a blank serial number, it will now generate a pseudo random serial number and program it back into the controller. That allows subsequent calibration only reflash operations to correctly license the controller.
    • Added LBZ Duramax tuning support.
    • Added new calibrations for LS1.
    • Added new calibrations for LS2.
    • Added 97/98 support for RoadRunner devices.
    Dec 23, 2006 (Update 3)
    • Added new calibrations for LBZ.
    New Scan Tool Features in V7.3.3
    Nov 10, 2006
    • Fixed PID validation for vehicles with separate engine and trans controllers.
    • Added LL8 and L52 in Customer details window (Displacement option).
    • Added 6 speed trans selection in Customer details window (Trans option).
    • Operating System list in the "Change VIN" window is now populated correctly.
    • Fixed VIN, OS and Trans being ignored when loading log files.
    • Added option to allow log files to be cleared without prompting for a filename.
    • The controller type must now be specified when connecting the Scan Tool to a vehicle.
    • Added new DMA PIDs for LS2.
    • Added LBZ Duramax scanning support.
    • Added support for scanning DMA PIDs for LBZ.
    • Added DMA PIDs for LBZ.
    Dec 2005
    [*]Script files can now be created automatically based on the differences between two files.
    You guys ROCK!!!!
    Member pkincy's Avatar
    Sep 2003
    Is this new software release for V2 only? Or is it also an upgrade for V1.2?
    Perry
    Oct 2004
    Also an upgrade for V1 users. Most of the functionality is aimed at V2 users in that it includes calibrations for E40 controllers and the new LBZ Duramax release.
    Andrew
    EFILive Crew
    the second link does not work for me?
    also do i need the new v2 to read the stock tune from a lbz? no right
    i have a lbz tune from a friend that he emailed me,i can read this
    but when i connect to my other friends lbz it says unrecongnized ecm?
    i have switched it to lbz,i have no problom reading my lly with the new upgrade version
    2017 Trailblazer 2.5L Dmax
    07 LBZ rc lb EFI - Sold
    05 lly cc lb, EFI 80hp tune-Sold
    01 lb7 rc lb EFI & Road Runner,1000+hp -Sold
    Duramax power
    Oct 2004
    The second link is the md5sum (checksum) of the download to verify it is not corrupt. I have calculated the md5sum and it is fce9385934e0dfa43d98cb7bcba8b619 if you want to verify the file.
    Have you installed this update? The unrecognised PCM may be an OS that we have not seen yet...
    Andrew
    EFILive Crew
    Jun 2006
    Garry Glendown * '17 Fifty 2SS MT
    Dec 2006
    this is my first efi download, is it suppose to take 2.5 hrs.? or is there something wrong with my notebook. thank you gentlemen.
    Oct 2004
    It is a ~95MB download so it shouldn't take that long, unless you are on a slow dial-up link?
    Andrew
    EFILive Crew
    Quote Originally Posted by jimmydiesel
    The download is 94Mb in size.
    With a 56K dial up connection it can take over 4 hours.
    With a faster (broadband) connection it can take as little as 2 or 3 minutes.
  1. EFILive 7.3 pre-release software has been updated - again
    Last Post: August 24th, 2005, 09:44 AM
  2. EFILive 7.3 pre-release software is now available
    Last Post: August 18th, 2005, 11:51 PM
