Page 1 of 9 123 ... LastLast
Results 1 to 10 of 90
Thread: Real-Time Automated Calibration System (RTACS)
    Thumbs up Real-Time Automated Calibration System (RTACS)
    Real-Time Automated Calibration System (RTACS) for GenIII
    EFILive’s R&D labs have produced the world’s first Real-Time Automated Calibration System (RTACS) for the LS1 PCMs. Based on the high performance Roadrunner real-time hardware; RTACS is a natural extension of EFILive's tightly integrated Scan/Tune feedback loop, used by tuners around the world for over 12 months.
    RTACS uses feedback from a Wide Band O2 sensor to allow the EFILive software to automatically adjust the VE Table (as an example) in realtime so the PCM's commanded Air Fuel Ratio's match those measured by the Wide Band O2 sensor. Because EFILive and RoadRunner use High Speed USB ports there is no lag in the real time system and changes happen instantly.
    With new features such as Map Masking, Data Filters, Target Indicators and both Fine and Coarse adjustments, EFILive’s real time tuning solution is impossible to beat.
    Map Masking allows the tuner to restrict the target cells so that the real-time calibration adjustments are applied to only that user defined subset of cells.
    Data Filters remove data spikes and transient values that would otherwise skew the feedback loop and produce erroneous results.
    Target Indicators highlight the cells that are within the correct percentage.
    Fine and Course adjustments allow for large adjustment early, followed by finer adjustments as the automated process nears completion.
    The EFILive RTACS feature gives your LS1 PCM true real time automatic tuning capabilities, normally only found in expensive aftermarket EFI computers designed for racing applications.
    EFILive’s RTACS is currently in beta testing and we expect it to be available in a week or two, along with some other software enhancements.
    As usual EFILive’s free software update policy means ALL EFILive customers will be able to download the new software package free of charge and those with access to a RoadRunner PCM can start using the real time, automated, calibration adjustments.
    Thanks,
    The EFILive Team
    Jan 2005
    This is awesome Ross!
    I may need to order my RR now instead of holding off for my trip to BR.
    Oct 2005
    Yay, where is the download?
    2008 Z06 C6 Corvette
    Jul 2005
    so it's basically continous series of copy and pastes of BEN's over the VE table?
    can you apply the same process to any other histogram/table?
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    I am going to say yes you can. If you have the correct pids selected, then it "should" be able to do what you want. Once I get more information on it and have a chance to play with it, I'll report back some more information.
    Aug 2004
    This is the BEST! Im using it all day today!
    Jan 2005
    Grind it in Jess
    Jun 2006
    Looks like this will make life easier for all of you professional tuners out there
    Garry Glendown * '17 Fifty 2SS MT
    Jan 2005
    This should make everyone's life a bit easier.
    Jan 2004
    I'll let you know soon enough.
  1. Automated license system
    By Biggsy in forum Purchase and Shipping
    Last Post: November 6th, 2008, 04:40 PM
  2. Spark tuning in real time....
    By Redline Motorsports in forum RoadRunner Real-Time PCM Emulator
    Last Post: April 18th, 2007, 10:15 AM
  3. RoadRunner Real Time Tuning
    By VT LS1 NZ in forum General (Petrol, Gas, Ethanol)
    Last Post: March 18th, 2006, 08:47 AM
  4. Live Real Time Tuning?
    By Nox in forum General (Petrol, Gas, Ethanol)
    Last Post: June 27th, 2005, 02:08 PM
  5. Real time tune ?
    By Clubsport R8 in forum General (Petrol, Gas, Ethanol)
    Last Post: March 30th, 2004, 12:13 AM
