Results 1 to 3 of 3
Thread: Updating FlashScan V2 Firmware
    Oct 2004
    Default Updating FlashScan V2 Firmware
    1) Unplug the RJ45 (OBDII) connection and the USB connector from the V2 interface.
    2) With the USB cable connected to your laptop, hold down the CTRL key on the V2 interface while you plug in the USB cable to the V2 interface. You should notice that some of the LEDs on the V2 now toggle side to side.
    3) Now open the Firmware Utility
    4) In the 'Update FlashScan V2:' section of the program click on the '...' button to locate the firmware file
    5) Once you have located the file (above step) click on the 'Program' button. Sometimes the numbers do not go all the way - this is not a problem, it still continues in the background.
    6) The FlashScan device will reboot on completion and the update is complete.
    Andrew
    EFILive Crew
    If updating firmware from 2.04.xx, then have a read of this:
  1. Having an issue updating Firmware
    By Leadfoot in forum FlashScan V2
    Last Post: December 7th, 2007, 05:20 PM
  2. Updating to BBL Firmware problems
    By WildChild in forum FlashScan V2 BB Logging
    Last Post: November 27th, 2007, 10:12 AM
  3. Updating to BBL Firmware problems
    Last Post: November 25th, 2007, 05:32 PM
  4. EFILive V2 Firmware Updating Instructions.
    By eboggs_jkvl in forum FlashScan V2
    Last Post: June 26th, 2007, 09:19 AM
