Results 1 to 10 of 16
Thread: Os Faq
    Jan 2005
    Default Os Faq
    What is this thread for?
    This thead is to cover frequently asked questions about PCM Operating systems (OS). This thread will be monitored and pruned on a regular basis.
    Can I upgrade my 1997-1998 OS to a 1999+ OS?
    Unfortunately, no. The '97 '98 PCM's are a different hardware platform and will not support the later operating systems.
    How do I upgrade my 1999+ OS to a later year OS?
    You will need the Commercial or Workshop version of EFILive in order to perform OS upgrades. Commercial and Workshop licenses can be purchased here
    Go to Holden Crazy and download a stock tune from a matching make model as you are upgrading.
    Edit:
    For those starting from scratch, Holden Crazy has been updated with stock 1999 calibrations on 2002 OS's. Currently you can download a 1999 A4 Camaro on 2002 OS and a 1999 M6 Camaro on 2002 OS. More conversions to come...
    Open two instances of the tune tool. In the first instance open your oringinal tune. In the second instance open the tune you are upgrading to.
    You will then need to copy and paste each table over. During the copy paste process, you will notice not every table between the two tunes exists in the other (i.e. back up ve table). Don't worry about these tables. You will also find in some tables, that the row's and columns are inverted. The tune tool has a utility that allows you invert tables. To get to this utility press ctrl+alt+enter.
    This may take you several hours to compete, but it is necessary. Just be patient and make sure you get every matching table copied over.
    When the copy process is complete, you will need to perform a full flash to get the later OS into your PCM.
    When the flash is complete, you want to download the tune from the PCM, then compare the downloaded tune to the tune you flashed into the pcm. There should be no differences. The comparison is a very important step to make sure the download was sucessful.
    How do I upgrade to a custom OS?
    From the scan or tune tool, click Help -> Tutorials -> Custom OS Upgrade Tutorial
    Jan 2005
    What tables are inverted?
    Quote Originally Posted by JR_VETTE
    Spark ECT Table
    Optimal Timing
    Catalytic Converter Light Off
    Jan 2005
    Which OS's are similar?
    I did this too, from 12202088 to 12212156, I found no inverted tables in this transition (or at least I didn't see any).
    Quote Originally Posted by Tordne
    12202088 and 12212156 had the exact same tables from my recollection Same with 12202088 to 12225074 (Holden 2001-2002 conversion).
    Last edited by joecar; August 28th, 2006 at 02:46 AM. Reason: Corrected OS id in joe's quote
    Jan 2005
    Tips on setting up Valet Mode
    http://forum.efilive.com/showthread.php?t=2386
    Jan 2005
    After reading the Custom OS Tutorial, How do I set up OS5?
    http://forum.efilive.com/showthread.php?t=2599
    Specifically:
    Here is the relink to that thread: showthread.php?t=2599
    Thanks Joecar
    Jan 2005
    Logging a 2+ BAR MAP sensor...
    Quote Originally Posted by onfire
    A 2bar map needs sae.map as the pid .....not gm.map...
    Jan 2005
    When converting from a 99 to 02 OS the following tables cannot be transfered:
    {B5911}
    {B5907}
    {B3334}
    {B3335}
    {B3336}
    {B6245}
    {B6612}
    There are various mis-matched tables between the OS's that have to "best-fit"
    "What are the differences between the various COS's...?"
    COS1
    restored dual spark maps for running in SD
    COS2
    Same as COS1
    Added Valet mode
    COS3
    Same as COS2
    Replaced B3605 (ECT vs MAP OL Fueling) with B3647 (RPM vs MAP OL fueling)
    IAT VE multiplier
    ECT EQ multiplier
    Added Boost VE table
    Added Boost Timing tables
    COS5
    Same as COS3
    added TPS vs MAP VE table
    additional functionality added for PCM Pin 56 (e.g. N2O).
    There was no public COS4.
    Lifetime Member BowlingSS's Avatar
    Nov 2003
    Quote Originally Posted by TAQuickness
    http://efiforum.iqd.co.nz/showthread.php?t=2599
    That is a very long thread for setting up COS5. Why not modify the toturial for the COS5?
    Bill
    2011 Camaro 2SS/RS L99 RJT
    CAI, Inc. Cold Air Induction;ADM Scoop
    Rx Catch Can;Rx Breather;Roto-Fab Washer Container
    VMax Ported RJT Throttle Body
    XSPower Headers and XSPower 3" Exhaust System
    Elite Engineering Tunnel Brace,
    Gorilla Wheel Lock System;
    Tinted Windows 35%;EFILive Tune
    Quote Originally Posted by BowlingSS
    Bill
    Bill,
    Good point, the tutorial should be updated to include the COS5 features.
    Joe
