Results 1 to 9 of 9
Thread: !VATS for remote start
    Member warscout2's Avatar
    Jul 2006
    Default !VATS for remote start
    is there any way i can remove the need for the little key pellet so i can us a remote start with out having to install a resister on a relay. im looking to be able to just deleate vats out of the pcm im not sure what the bcm has to do with it.
    can some oneplease help?
    No problem.
    With the tun file loaded go to -
    System > Theft > Parameters (or type G1201 in the navigator window).
    Then change G1201 to 'None'
    That is it, now you don't need the coded key to get the engine to run.
    Aug 2004
    The BCM will keep the vehicle starter from cranking though, you will have to just jumper over the purple wire to your switch relay.
    Jul 2006
    what purple wire and how do i jumper it?
    do i need a bcm?
    Aug 2004
    IF you dont have a bcm and the starter works when you turn the key then you are good to go by just shutting off pcm vats, If you have a car that has Vats system in it, it is a 2 part system. BCM blocks starter, pcm shuts of spark/fuel.
    Jul 2006
    i think i have a bcm and im not sure how to jumper it
    Jan 2007
    you can just measure the resistance of the pellet in your key, then find a resistor that has the same resistance, then go to the base of the steering column and find the orange wire harness that has two small white wires inside.
    unplug the connector, on the body side of the harness solder in the resistor that you selected from the above test, thats it. (if you put a switch in the circuit you can still disable the car when parked)
    Jul 2006
    ya i already fixed it i just forgot to update my post
    mrrattle, welcome to the forum.
  1. LMM - another No remote start after ECM swap
    By Cougar281 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: February 8th, 2010, 11:51 AM
  2. Remote Start configuration
    By Max Power in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: October 5th, 2009, 04:24 AM
  3. Pontiac G8 remote start not working
    By KenB in forum E37, E38 & E67 PFI ECM's
    Last Post: February 11th, 2009, 05:14 AM
  4. LMM ECM swap problems....no remote start
    By DuramaxPowered in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: January 29th, 2009, 12:00 PM
  5. remote laptop screen ????
    By Delco in forum General
    Last Post: July 11th, 2006, 01:25 AM
