I have the new 555 build software and I downloaded the extra cal. files and I still cant get a copy of the tune ,It keeps on bringing up an error code. Any help would be appreciated .By the way its a 2000 1500 Silverado
When you do a read of the PCM what is the OS # shown?
Andrew
EFILive Crew
A calibration has not been released for that yet. Can you forward the tune file to support at efilive dot com. We can then look to add support for it (if it isn't already done).
Andrew
EFILive Crew
Ok I sent it over thanks for the help.By the way there is a calibration file with the same number ,it might already be done?Originally Posted by Tordne
I have just forwarded the file on. It may be an OS that we haven't seen before in which case it will need a cal made for it. It may already be done but not shipped. We'll see soon![]()
Andrew
EFILive Crew
all the vortech cals are supported. You must not have put the zipped files into the correct folder. You need to move the contents of the zipped folder to c:\\Program Files\EFILive\V7\Calibrations
The files can not be zipped when in that folder so make sure it is just the seperate files you put in to the calibrations folder. 16265175.cal is an example of the file name that needs to be in there.
