Results 1 to 10 of 19
Thread: 4L80E 4rth Gear problem
    New Member almusafir's Avatar
    Feb 2007
    Default 4L80E 4rth Gear problem
    I have to face one problem from 7/8 days...
    in Transmisasion 4L80E We overhaul it...
    now the problem in 4rth Grear
    I have this Transmission in GMC Truck 454 Engin Model 1990.
    Shifting is OK.. But
    When It became in 4rth Gear and I press the full accelator the care take the kick down and become in 3rd... then its runing in 3rd.. never became 4rth until you stop the car. and switch off the Car..
    Can you please help me for this..
    Almusafir,
    Welcome to the forum...
    Please post your .tun file (do Go Advanced->Manage Attachments, and then Browse, Upload).
    When this condition is present (no 3-4 shift after 4-3 WOT), do you get these shifts:
    - 3-2 kickdown (WOT)
    - 3-2 part throttle (PT)
    - 2-1 PT
    - 1-2 PT
    - 2-3 PT
    If you get thes other shifts, then possibly the 3-4 shift valve may be sticking.
    Attached page is from the 4L80E Technician's Guide.
    When this condition is present, monitor the GM.GEAR and use the BiDirectional controls to command 1st, 2nd, 3rd, 4th;
    does GM.GEAR show each of these being commanded...?
Name:	4L80E no 4.png
    Default No Fourth Gear - D4 (from the service manual)
    Checks Cause
    Fourth Clutch Components
    • Seals (527) (531) Nicked or cut
    • Cup Plug (530) Missing
    • Bolt (26) Loose, broken, or missing
    • Piston (528) Jammed
    • Spring Assembly (532) Jammed
    • Retainer Ring (523) Not seated
    • Friction Plates (525) Worn or burned
    • Reaction Plates (526) Worn splices
    • Housing (529) Damaged or cracked
    Overrun Clutch Components
    • Housing (504) Broken
    • Reaction Plates (508) Worn splines
    • Sun Gear (650) Worn
    • 1-2 Solenoid (313) Stuck Off, Pinched wire, O-ring failure, No voltage to the solenoid
    • PCM No signal to the solenoid, Failed
    • 3-4 Shift Valve (308) Stuck
    Check the PCM for current DTCs.
    Last edited by joecar; February 28th, 2007 at 04:59 AM. Reason: This was a nice table in html, but it isn't being interpreted right...?
    I assume you are using a Gen III/IV PCM and have fitted the necessary hardware to your 454 for the PCM to operate the engine and transmission...
    Which part of my assumption is incorrect...?
    Feb 2007
    Almusafir,
    - 2-1 PT
    - 1-2 PT
    - 2-3 PT
    Thanks Sir...
    But still same problem..
    it appear code no 68
    I don't have an early GM manual with me right now, what does DTC 68 mean...?
    Oh, you're using the OBD-I ECM.
    Lifetime Member Biggsy's Avatar
    Jan 2007
    Off the top of my head I believe code68 is a trans slip fault
    Dave.
    Feb 2007
    Yes...
    I 'm using OBD-I ECM..
    I think Code
    68 means
    Cruise control - system
    circuit problems.
    OR
    Air Conditioner (A/C)
    clutch relay - short circuit.
    OR
    (Transmission) Overdrive
    ratio error - engine RPM
    greater than input speed.
    Feb 2007
    Quote Originally Posted by Biggsy
    No Sir code68 appearing...
    Transmission Shifting is fine and OK.. But when you became 4rth Gear and you press full accelator it takes Kick down and coming in 3rd... Then it never change of 4rth.. until you stop and switch off the car..
    When you shitch off the car and start is again its ok in normal
    "Overdrive ratio error" means the fourth clutch is not applying;
    when the fourth clutch is applied, it holds the overdrive sun gear stationary which causes the overdrive carrier assembly to "overdrive" the forward clutch housing (where the input speed is measured).
    Edit: if the fourth clutch is slipping or not applying, then the input speed measured at the forward clutch housing will be wrong, and the PCM raises the code.
    See the blue, red, gold components in the next post...
  1. 4l80e 4th gear and tcc problem (running from 4L60E segment)
    By kkustomz in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 28th, 2011, 02:05 PM
  2. Why does 1st gear slam into 2nd? 4L80E translplant
    By 1SlowHoe in forum Gen III V8 Specific
    Last Post: May 22nd, 2010, 09:47 AM
  3. 4L80E TCC problem
    By Arnoldi in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: March 19th, 2010, 11:26 AM
  4. manual gear selection overide 4l80e
    By 2500ak in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: January 6th, 2010, 04:48 PM
  5. 4L80E 2nd & 3rd gear only
    By rickwils51 in forum 4speed RWD/FWD Transmission Tuning (incl T42)
    Last Post: November 1st, 2007, 06:06 AM
