My 07 LBZ has a 3500 RPM limit on it. Anyone know where to play with the tunes to remove this or raise it.
Thanks,
Rob
Thanks,
Rob
B1122 is more than likely the problem, it will limit the fuel amounts to 30mm3 at and above 3500RPM, though, because of the table interpolation the limiting will probably start to kick in at around 3300 - 3400RPM.
If you raise the values in that table at the higher RPM the value will be carried through to higher RPM's (the table ends at 3500). You also need to look at B1117, B1118 & B1119.
I figured those tables would be the ticket. I'll try adjusting those today and testing.
I was also looking at the "pedal pos. to desired torque" table. Torque starts falling off at 3250rpm's and goes to 0 at 3550rpm
Ross, what is the difference between B1118 and B1119?
Thanks,
Rob
OK, a little update.
I modded the B1118 and B1119 and still hit the 3500rpm limiter. I then modded those as well as "pedal pos. to desired torque" table and still have the RPM limiter.
I logged the runs, but haven't had time to look at them.
I'm not sure where to go from here.
EDIT: Dooouuuh, I forgot to mod the B1122 also. I'll do that and see.
Thanks,
Rob
Well even with the B1122, B1118, B1119 modded I still have the 3500rpm limit.
Any thoughts?
Some logs would help if possible Rob, I'd like to see what the Main mm3 is dropping to if possible.
Ross,
I sent a couple logs. Hope it went to the right place (support@efilive)
Looks like the main flow rate drops a bunch and the turbo vane position goes to 0 for a bit. Any way to mod the flow rate and duration like the old platform?
Thanks a bunch,
Rob
Thanks Rob, I got the logs.
I forgot to ask, did you change the upper RPM cols in B1115 & B1116? I only ask because on a stock LBZ the desired torque figures plumet between 3250 and 3500 RPM (which will drop the main mm3 numbers), just like your commanded fuel drops from around 80mm3 down to 28mm3 over a similar RPM span.
I did change B1115 and B1116 Ross. Thats what is bugging me. I can't seem to control it with any of the available tables.Originally Posted by GMPX
Thanks for your help.
Well, that's what you get for trying to rev it like a gasser .Originally Posted by IdahoRob
Did you notice if the logged torque value also dropped?
I'll keep looking I guess.
