Results 1 to 7 of 7
Thread: how to copy settings from old tune
    Mar 2007
    Default how to copy settings from old tune
    I had a 00 os f-body....now have 02 os COS5. I would like to copy all my tranny up/downshift settings over to the new tune but efilive seems to give me a "no can do" since the OS are different. is this correct? I just didnt want to have to enter them all manually
    Jan 2005
    you can open two instances of the tune tool. From the original tune, "copy with labels", then in the new tune "paste with labels".
    If the tables between the two tunes are transposed, you can use paste your data into the conversion tab, transpose, copy with labels, then paste into your new tune.
    Mar 2007
    slick!! Thanks...i will try that Like dating 2 chicks at once...just cant let them know about each other
    Guess who's back!!!! Black02SS's Avatar
    Jan 2004
    Compare a stock 00 Tune to your Modified 00 Tune. Create a script based on the differences that appear. Open your 02 OS5 and apply the script. Done in about 5 mins.
    Mar 2007
    i dont want to copy anything except the shift points. Everything else I want to start fresh
    I couldnt open the file you modified Chad. It is os 0202005....i dunno what the "5" is but my efilive wont open it...i am using 0202003
    Jan 2005
    Chadwick - Please send me the tutorial on that feature. I've yet to toy with scripting.
    Quote Originally Posted by TAQuickness
    Me too, I have heard of this scripting but never used it. Sounds promising though!
  1. Download Tune Settings
    By Coker6303 in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: July 31st, 2008, 08:19 AM
  2. Can't copy my old tune to new OS#
    By Boost in forum Duramax 06 LLY / 06+ LBZ & LMM
    Last Post: March 11th, 2007, 02:30 AM
  3. Copy of tune
    By Dlong in forum General (Petrol, Gas, Ethanol)
    Last Post: April 22nd, 2006, 09:35 AM
  4. Do I return settings after SD tune is complete?
    Last Post: October 9th, 2005, 06:53 AM
  5. NEED TO COPY SOMEBODYS 3 BAR TUNE!!
    Last Post: August 21st, 2005, 12:56 PM
