Results 1 to 4 of 4
Thread: Reinstalling V2 drivers
    Jul 2005
    Default Reinstalling V2 drivers
    Was wondering if anyone else had ran into this. In January I finally took my V2 out of the box and installed the software onto my new laptop, updated everything to V7.3 updated the firmware and USB drivers, and transferred my unused licenses from the V1. Checked on my truck and everything worked fine. Put everything back in the box until yesterday, when I pulled it out to tweak on the Trans Am. The laptop would not recognize the V2 or V1 cables. When I plugged in either the V1 or V2 cable, I got the "New Hardware Found" message, Windows didn't know what to do, and Scan or Tune would not see the cable. The V2 box would talk to the car on its own just fine, but not the laptop. After much cussing and gnashing of teeth, I deleted then reinstalled the FlashScan USB drivers, and it all took to playing nice again. What the heck was that all about?
    '03 GMC 1500HD
    '79 Pontiac LeMans-LQ4/4L80E
    '05 CTS-V
    Maybe between the first and subsequent driver install, you installed some other USB device. Sometimes similar USB devices use the same driver names but not the same driver versions.
    Anyway, V7.4 is out now and it has all new driver versions.
    http://forum.efilive.com/showthread.php?t=4442
    Lifetime Member Bruce Melton's Avatar
    Oct 2003
    And I assume the same drivers are the best for V1?
    PowrMax Performance
    100 mm PowrMAF
    Quote Originally Posted by Bruce Melton
    Yes.
  1. USB drivers Pop-up
    By white01ss in forum FlashScan V2
    Last Post: June 5th, 2008, 04:40 AM
  2. V1 and V2 same USB drivers?
    Last Post: March 27th, 2007, 06:51 AM
  3. v3 usb drivers
    By ZL1Killa in forum General (Petrol, Gas, Ethanol)
    Last Post: February 15th, 2007, 06:20 PM
  4. USB drivers
    By killerbee in forum General (Petrol, Gas, Ethanol)
    Last Post: August 30th, 2006, 12:28 AM
