Results 1 to 8 of 8
Thread: Help
    Apr 2006
    Default Help
    Loading efi and it won't let me scan or load tunes. Says this version is not compatable with the cable.
    I've loaded all the lastest versions, any guesses?
    Tranny tonight, track tomorrow, if I can get this efi thing running.
    Thanks,
    Rob
    __________________
    When you intalled the latest V7.4 software, a new FlashSCan V2 firmware file was included (V2.4.55).
    Hold down the Ctrl button on the FlashScan keypad, while connecting it to the PC. That will cause 2 orange LEDs to flash indicating that FlashScan is ready for the new firmware.
    Please selet the Start menu option:
    Start->All Prorgams->EFILive V7->Update FlashScan V2 Firmware.
    Click on the [...] button and select the firmware file:
    \Program Files\EFILive\V7\FSProg_V2_4_55.ffw
    Then click on the [Program button]
    The programming should only take 20-30 seconds.
    Once the FlashScan logo displays on the FlashScan V2 screen, you're good to go.
    Quote Originally Posted by IdahoRob
    Thanks,
    Rob
    __________________
    Aug 2004
    If that dont work. Call me at 574-267-3630 i will get you taken care of asap for your race.
    Apr 2006
    Thanks guys, I really appreciate the help. Well we gave it our all on the truck. We got the twin turbo set-up done in two and 1/2 days(one of those today) and then tore into the tranny tonight. We ran into a couple of problems with the trans stuff, so looks like no race day tomorrow.
    We'll still try to get in a few passes if we can get a part and get it back together tomorrow.
    I haven't tried the fix for my efi problem yet, but will tomorrow.
    Thanks,
    Keep us posted Rob, looking forward to hearing your results (on the twin turbos).
    EFILive Distributor Trippin's Avatar
    May 2004
    Rob,
    I'm here if you need me.
    Guy
    www.socaldiesel.com
    EFILive-DSP5......Switch your Attitude!
    EFILive-CSP5......The Smart Way To Switch Your Cummins Tunes!
    EFILive-DSP4......Switch Your Colorado and Canyon Too!
    Looking forward to seeing you get all fix-ed up and start flying down the 1/4mi! Ive never seen a D-max (or anything else) run in person, but I really want to this summer.
    Apr 2006
    Quote Originally Posted by Trippin
    Rob,
    Guy
    Thank-you Guy. Just a mistake on my part as usual. We followed the above procedure and everything works
