Hi Guys,
When recalibrating your speedometer you need to check the values and make sure you are putting in valid information for you application.
There have been 2 instances on corvettes where the pulses per revolution have been modified to a very high number which made the pcm go into a cpu 100% loop. The cause is by playing with the speedometer calculator and unchecking the "Transaxle" box.
IF YOU HAVE A CORVETTE, YOU NEED TO LEAVE THAT BOX CHECKED! If not it will change the calculated pulses per revolution to 40 making the H0101 table go to an obscene value.
An update will be posted that will force the transaxle box to be not changeable from now on. Also a Max H0101 value will now be in made so only reasonable values can be entered....
IF anyone has any problems or questions, Call or email me and i will answer your questions. Also if you somehow have a non responsive computer then send it my way and i will fix it and ship it back out for free.
The only vehicles that may be effected with this are only certain corvettes and only if you unchecked the transaxle box when modifying speedo cals.
