there are two vin included with initial purchase correct?? if so i am having problems flashing the second pcm first one went just fine. in the tuning tool under v2 license it still shows #2 slot is avaible. any help Thanks!!
Welcome to the forum 94caprice00gmc.
Are you getting a particular error code/message when you try to flash the second PCM?
it is just saying : There are no free license slots available in the flash scan cable
Are you running the latest beta update for 7.4? There was a problem with the Tune Tool not recognising the last license.
See: http://forum.efilive.com/showthread.php?t=4890
yes i already installed 7.4 should i reinstall every thing to make sure?
oh brain fart do i need to download update 02?
oh never mind i got it to work the 02 update wasnt in the right folder thanks again for the help
Ryan
