Results 1 to 7 of 7
Thread: Problem with commanded AFR in OS5
    Apr 2005
    Default Problem with commanded AFR in OS5
    I am having an issue with commanded afr in OS5 it would appear. I am getting values logged that I don't have in the commanded open loop table. I'll attach a log as well as the cal...maybe I'm missing something but I don't think so. At Idle it showing commanded afr of 10.29.... Any help is greatly appreciated!
    Jason.
    Oct 2004
    I'm sending you a PM.
    Andrew
    EFILive Crew
    Apr 2005
    I definately am missing something, becuase according to efilive, B3647 isn't available in the OS5 (when I do a search for that table). I set B3605 as stated in the auto ve tutorial. B3607 is a single entry value, I had this at 0 (which is where it was from the factory). I guess I'll put that at 11.5 but I can't see how that is the issue.
    Any ideas? Did I do the update incorrectly?
    Thanks for the help.
    Jason.
    If you are using 02020005 then there was a .cal file that did have a table labeled wrong. Use the attached one instead.
    Ross,
    Is that cal file newer than the one in build 515_644_622_55 (April 20 release)...?
    Joe
    Oct 2004
    I'm pretty sure the 7.4.2 release has all the updates rolled in to it.
    Andrew
    EFILive Crew
    Lifetime Member Doc's Avatar
    Oct 2005
    Can you post up a full list of your mods?
    www.efialchemy.com
    www.greatamericancarwar.com
  1. GM.EQUIVRATIO PID = 'commanded EQR'?
    By Mr. P. in forum General (Petrol, Gas, Ethanol)
    Last Post: December 4th, 2009, 12:08 PM
  2. Questions on commanded AFR
    By LS1_Dragster in forum Gen III V8 Specific
    Last Post: July 9th, 2009, 08:59 AM
  3. “Un-commanded” AFR at WOT
    By Rontune in forum Gen III V8 Specific
    Last Post: July 3rd, 2009, 02:58 PM
  4. commanded WOT Afr Im confused
    By blazinblue in forum General (Petrol, Gas, Ethanol)
    Last Post: May 14th, 2009, 04:32 AM
  5. commanded afr
    By 69camaro5speed in forum General
    Last Post: December 29th, 2005, 05:42 PM
