Page 2 of 7 FirstFirst 1234 ... LastLast
Results 11 to 20 of 61
Thread: Stock GEN IV Files
    Quote Originally Posted by Bob's Garage
    Can you please tell me if the following LS2 controller is supported?
    VIN
    1G1YY24U955100573
    Thanks....
    Based on the fact that 10th digit of the VIN 1G1YY24U955100573 is a 5, that is a 2005 vehicle and from the 1G1YY part, it is a Corvette so that can only be an E40 based vehicle (as I mentioned before, ALL 2005 model year Corvettes are E40). That means the current release of EFILive will support that vehicle. The current operating system for that VIN is 12613186 and that operating system is supported by EFILive (as is the one prior to it for that vehicle).
    Jason
    Jason Haines, Project Director
    Lingenfelter Performance Engineering
    http://www.lingenfelter.com
    [email protected]
    260-724-2552
    Apr 2005
    I am still having a problem viewing the operating system. I get the "unrecognised pcm" message.
    In the calibration tab the OS is 12595751
    I saved a copy of the tune and sent it to support@efilive
    For anyone interested I can snd them the file to see if you can read it.
    Just sent me your email and I will send the file.
    email me at [email protected]
    I would greatly appreciate someone looking at the file.
    Thanks inadvance.
    Bob
    Oct 2004
    There is nothing "wrong" with your file that anyone can "fix". It is just a case of the calibration file not existing for the specific Operating System and therefore not knowing what the data relates to our how to present it (in the form of tabkes etc).
    There are heaps of calibrations being created currently for the new E38/E67 and other controlers for which read support was released recently.
    The calibrations are due out fairly shortly.
    Andrew
    EFILive Crew
    The vehicle he is talking about is a 2005 so it is an E40, not and E38 or E67, so it should already be supported.
    Jason
    [email protected]
    260-724-2552
    Default E40 Corvette operating system file support
    Per the GM TIS web site, that VIN should have one of the two following operating systems:
    VIN:1G1YY24U955100573
    Controller:PCM/VCM
    Powertrain/Vehicle Control Module Calibration History for: Main Operating System
    Part Number
    • 12613186
    • 12605740
    Both of those operating systems are supported by the current EFILive software.
    I am not sure why your vehicle is showing 12595751 as an operating system. Are you sure you are looking at the correct file tab because that part number is the speedometer calibration file part number for your vehicle. Are you using the latest EFILive software that supports E40?
    If you are still having these issues I would get your vehicle flashed by a dealer to the latest stock calibration files and that should give you the correct operating system (or you can do it yourself if you have the software/hardware to do so).
    If you had a stock EFILive calibration with ALL the correct files for that vehicle, you could also use EFILive to update the vehicle.
    BTW - anyone can check what the correct files are for a specific VIN GM vehicle by going to:
    http://tis2web.service.gm.com/tis2web
    Jason
    Last edited by jrh; May 18th, 2007 at 01:20 AM. Reason: The table format and tabs didn't provide proper layout once posted and then I made a typo.
    [email protected]
    260-724-2552
    Apr 2005
    Jason
    You are correct however, for this EARLY pcm OS, 12595692 EFILive does not yet have a cal file.
    Ross is working on as we speak to help here.
    PLease check your E40 cal file folder to see if you have a ...692 cal file.
    I am working with Brent at EPP. He ma be contacting you today on this.
    I sent him my stock tune.
    Bob
    Bob,
    Just update the ECM to the latest files and this won't be an issue anymore.
    Jason
    [email protected]
    260-724-2552
    Jun 2007
    I just sent you a stock 05 gto a4 program and a stock 06 6 speed program.
    cosmos purple 2004 gto
    408 E85 GT47-91 ,turbo 400,9" currie straight axle,28/10.5w mt et streets
    2005 yellowjacket gto
    417 rwhp and 397 torque
    582 rwhp and 676 torque (150 shot)
  9. #19
    12595692 should be in the current release download FYI.
  10. #20
    Jun 2007
    Quote Originally Posted by Black02SS
    If you guys would, please send your stock GEN IV files as well as a description to either Tordne or myself so they can be added to the list.
    www.holdencrazy.com
    did you get the files I had sent you?
  1. Stock LS3 tune and trans files..
    By Chris81 in forum Gen IV V8 Specific
    Last Post: April 20th, 2008, 12:57 PM
  2. EFILive Stock *.tun Files!!! In Here!!!
    By Black02SS in forum General (Petrol, Gas, Ethanol)
    Last Post: March 12th, 2008, 07:45 AM
  3. E38 stock files needed
    By Lennart in forum E37, E38 & E67 PFI ECM's
    Last Post: February 10th, 2008, 04:42 PM
  4. Stock tuning files, All years please!
    By ScarabEpic22 in forum LL8 4.2L In-Line 6 - P10 PCM
    Last Post: August 17th, 2007, 06:48 AM
